PKE fob plastic
Old Mar 30, 2017 | 03:48 PM
jmgtp's Avatar
jmgtp
Default PKE fob plastic
What have you done to repair the plastic? Mine has the common break at the key ring. Been this way since I bought the car in 2009. Currently is rigged with some wire. Looks like crap. Doesn't appear to be any plastic shells available.
Old Mar 30, 2017 | 11:23 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
I found a place online that had the remotes and the cases when I bought my rag, of course..no better than the alarm works....
I'll look and see if I saved the link in my bookmarks or records.
later, tiny
Old Mar 30, 2017 | 11:48 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
Here ya go...click on the link, shell only. later, tiny
Amazon Amazon
Old Mar 31, 2017 | 11:45 AM
Mayor111's Avatar
Mayor111
Just read the review there - one guy said the FOB circuit board doesnt fit from his original. Also, looking at the pictures, it shows they SNAP together vs. screw together - not sure if that is how the board secures inside...
Just wanted you to be aware...
Old Apr 1, 2017 | 12:56 AM
tlong's Avatar
tlong
There is more trench art done to key fobs than WW1 Enfields. Mine has leather, plasic and a red case from somewhere. Drilled, glued. painted....
The car is completely stock, the fob is totally custom.
Old Apr 1, 2017 | 06:25 AM
hcbph's Avatar
hcbph
The other year I had a cracked fob for my truck. I could not find another of the same 'model' number or just a case. What I did find was who made it then started looking on Ebay. I found some used ones that were the same case but a different fob model number. I bought one, swapped out the guts of mine in to that case and had a perfectly good fob again.
Old Apr 1, 2017 | 05:33 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
Nuts !
later, tiny
Old Apr 3, 2017 | 11:19 AM
Red Dwarf's Avatar
Red Dwarf
Contact Bree at this address. c4fob@yahoo.com
She has new fobs (complete) for around 100 dollars shipped.
Old Apr 3, 2017 | 12:54 PM
TorchTarga94's Avatar
TorchTarga94
This
The earlier fobs were snap together and the later fobs used two screws to secure the shells. The later style are much more durable and can be used on the earlier PKE cars.
Old Apr 3, 2017 | 03:48 PM
jsmn4vu's Avatar
jsmn4vu
Right. There are replacement shells available for the newer (two screws) fobs, but none that I know of for the earlier (snap together) ones. The guts are NOT compatible without a lot of plastic work.
Old Apr 3, 2017 | 07:46 PM
jmgtp's Avatar
jmgtp
Thank you for the replies everyone, seems there are some options.
Mine is not secured by screws, which I guess makes it the early type and seemingly incompatible with the case on Amazon. Too bad, as that seemed a good option.
Old Apr 8, 2017 | 09:09 AM
Sprongs's Avatar
Sprongs
This is what I use, works great for me, http://www.remotetotes.com/
Old Apr 8, 2017 | 12:00 PM
Red Dwarf's Avatar
Red Dwarf
Great idea. Thanks!
Old Apr 26, 2017 | 10:29 PM
Klondike's Avatar
Klondike
Default Beware the ones on Amazon
My own fault for not reading every post in this thread!
The guts for the 96 PKE will not fit inside the nice new shell case I just wasted my money on. The inside of the shell has some stand-off posts or maybe they are alignment posts for some other type of CKT board. Also the screws that hold the shell together are right inline with the board, so if you DID modify the insides to fit the ckt. board, then you would have no way to hold the halves together. Their advertising is grossly misleading as to what years it will fit.
To PKE fob plastic
