headlight problems
Old Mar 31, 2017 | 06:49 PM
redmc123's Avatar
redmc123
4th Gear
Default headlight problems
My C4 drivers side headlight is working but when I turn on or off the headlight makes a popping sound and the actuator arm moves causing the noise. Do I need to replace the motor or is there something else that's broken. This popping noise eventually stops and both headlights open and close
Old Mar 31, 2017 | 07:48 PM
Renfield's Avatar
Renfield
You can disconnect the neutral motor wire at the connector. Then just use the manual dial on the motors. I keep mine down in the summer and up in the winter.
Or you can fight a bad design with all your wallet.
Old Apr 1, 2017 | 10:28 AM
RUU's Avatar
RUU
Or if you've got a 1988 or up, get a bushing repair kit.
http://www.parts123.com/corvettecent...50f&ukey=09294
Old Apr 1, 2017 | 11:14 AM
MrJoelieC's Avatar
MrJoelieC
Welcome to Corvette #1 issue that drives us nuts
Watch this video:
Click Here Click Here
for pre-populated link to all options on amazon... Personally, I think the bronze gear is appealing but the price is "not so much" and the plastic options lasted for 20+ years.... SO take your pick
Old Apr 1, 2017 | 11:34 AM
pucksdown's Avatar
pucksdown
Go ahead and replace the bushings in both headlights. If one is going bad you can bet the other is too.
Old Apr 1, 2017 | 12:22 PM
MrJoelieC's Avatar
MrJoelieC
Old Apr 1, 2017 | 12:31 PM
belairbrian's Avatar
belairbrian
The pile of rubble is what I took out.
The delrin bushings went in. No More clunking before moving.
To headlight problems
