Head light will not rotate
Old Apr 13, 2017 | 06:33 PM
Oregon Rb's Avatar
Oregon Rb
1st Gear
Default Head light will not rotate
My 1989 corvette right head light will not rotate, the light comes on but will not spin. I replaced the motor but still nothing, when I read voltage at the 2 pin connector I see no volts, I read voltage on the working left side and see about 4 volts so I guess there is a relay some place that might be the problem...ps the motor does not ingage at all..
Old Apr 14, 2017 | 01:11 PM
bac22's Avatar
bac22
Probably the Headlight Opening Actuator Module has gone bad. I seem to recall (at least on my 96) you can reverse connectors to see if the problem swaps sides.
http://www.ecklerscorvette.com/corve...1984-1996.html
