90 C4 popping and won't accelerate
Ok, i added cleaner to the fuel, changed the plugs, wires, ignition module, and fuel filter, still wants to stall when giving it gas. Starts fine, a bit of a rough idle (just a little). Used one of those automotive stethoscopes on the injectors, all sounded the same/even (doesn't mean they aren't clogged though). I guess the next steps are checking the fuel pressure? Any other suggestions?
Thanks!
Thanks!
How is your spark? Lets do this at night. Make sure you have a new plug gapped. Do each cylinder and see if you have a blue flame. Sure, it will run rough on 7 instead of 8 but WGAS?
Also scan for the engine temp and do an infra red thermometer on the ECT (not the gauge) sensor. That way, if the ECM sees 120 and the thermometer says 180, you have a problem.
As to your injectors, they are definitely dirty and/or Multec. For what you get reman ones for from FIC, you probably would be better off changing them. While they are out, you can take the TB off, do a coolant bypass, take the top plate, IAC and IAC housing off and clean the passages. Reinstall with new gaskets. DO NOT PUSH THE IAC PINTLE. Spray with brake cleaner and wipe GENTLY.
Step one was to check fuel pressure, but the real issue could be the "pick up sock" aka the pre filter
takes 1/2 an hour to remove the pump assy. get you some,
buy the whole assy if you can, ac delco or delphi .......rock auto?
denso or carter would be my alternate choices
plugs and plug wires, nice .......post pics of knuckles and wrists
Pro Mechanic
The new fuel pumps are a turbine style that do not require the pulsator and just include a piece of fuel rated hose to replace the length where the pulsator is removed from. The older style pumps were a gear-rotor style that delivered the fuel in little pulses as each gear came around and needed the pulsator as a "shock absorber" to smooth out the flow to the injectors. The new turbine pumps are smooth delivery and don't require that extra damping.
Easy to siphon gas out of a C4 but not really necessary for a pump change.
Good information. I actually prefer the Ractronix kit for ease of assembly. It comes with the gasket and new SS hex head bolts. For $30, it is worth it. No trips to the store.
Pro Mechanic
Guys, you don't need to empty the tank at all in order to change the pump.
Just pull it out, stick the new one in.
But first, diagnose that it needs a pump.
Timing and or fuel.
Fuel filter, injectors, TB, timing. Possible computer issue since its a '90.
Did it run fine before?
Bad gas is NOT the issue. My car sat 10 years until 2 years ago with the same gas and no additives. I have never used additives. never had an issue.
And take the fun out of it? Nah. Why, I'll bet it is because the PO ran the car low with less than a quarter tank that caused the pump to burn.
Seriously, you are correct. We don't even know if fuel delivery is a problem.
'The year IMO but mine had a similar issue 2 years ago. Only it would eventually even die at 5,000rpms. Several of the top tuners and tune writers here and other more sophisticated forums for FI tried to fix it and could not.
I'd say a very small chance it's that and totally and completely last place to check.
We don't know if some weekend pit crew guy with a tuner was in his car's system either trying to play tuner.
http://repairpal.com/engine-control-...m-can-fail-350
Ok, checked the fuel pressure, 38 psi. Checked the vacuum, 18 psi. Still the same, starts fine, revs fine the first press of the gas, the next press of the gas, it stumbles and pops, and if you hold the gas pedal down it'll bog and just about stall.
#33
The fuel pressure at 38 is a tad on the low side. You should connect a fuel pressure gauge and tape it to the windshield and drive the car and check the pressure under load. If the pressure drops you could have either a regulator or a pump problem.
#34
I'm not sure what the vacuum has to do with this test. You turn it on and it jumps up before cranking. After that, the next thing we need to see is whether it holds pressure.
#35
low??? Service manual says 34-39.
#36
#37
#38
#39
Pro Mechanic
Pump may very well meet the requirements at idle. Your symptom is not occurring at idle, however.
#40
