recommend excellent fitting carpet package please
Old Apr 22, 2017 | 10:11 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Default recommend excellent fitting carpet package please
hi guys, after turning my faded medium gray carpet's into a mangy coyote pelt that looked like it fought with a bucket of blue bic pens, I ordered a set of the auto custom carpets BUT just cancelled because of reviews like this: https://www.corvetteforum.com/forums/transactions-feedback/3671597-acc-carpet-review.html
i cant handle any more fe(kery with carpets. i need these to carpets to just show up, and fit. i dont care how much they cost.
can you help me out by recommending a set you have used that fir perfectly and you would give an excellent review of. thanks.
note my car has dynomat installed already if that makes any difference.
thanx and happy saturday night. im going to pour a drink.
Old Apr 22, 2017 | 10:18 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
Originally Posted by VikingTrad3r
hi guys, after turning my faded medium gray carpet's into a mangy coyote pelt that looked like it fought with a bucket of blue bic pens, I ordered a set of the auto custom carpets BUT just cancelled because of reviews like this: https://www.corvetteforum.com/forums...et-review.html
Perfected by the 16 men of Tain perhaps ?
later, tiny
Old Apr 23, 2017 | 12:57 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Unless things have changed (and it's probable), there may only be two choices. Maybe we're down to one?
Regardless, call Wilcox. Of any vendor, that's the guy I'd trust with a question like that. If they have two "levels", pick the one he recommends.
10 years ago, I picked the lower-quality (non-NCRS). I got if from Mid-America (I think). It was a set they started to install "in-house", then swapped to the higher quality. It was black. I received substantial discount and picked it for that reason. It was probably 25% off or thereabouts.
I too, dynomatted my car (per se). There was a bit of "fitting" here/there but the important areas were pre-molded. If anything, I think I had to wrestle an area/two behind the seats OR in the cargo area. Hard to remember after all this time.
Point being....I wasn't disappointed with the quality, fit, or amount of effort necessary to redo the car. I didn't bother to read the link you provided because of the timeframes and because I suspect FLAWED carpet is returnable.
The post above is probably indicative of the fact it's going to require SOME work. But it's not that hard. Basically, you cut/trim with a box knife to achieve good fit. Again, important areas: like floor pans, jam transitions, tunnel humps, etc... SHOULD be pre-molded. And, Wilcox SHOULD be the best place to point you to the quality/brand best fit for your needs. And, if they carry that brand, you'll like their policies.
Old Apr 23, 2017 | 11:12 AM
VikingTrad3r
Oil Producer
Default second carpet question
annybody recommend a uv protectant spray for the. new carpet?
ive researched scotchbrite and it doesnt advertise as a uv protectant. same with 303.
looking for a spray on and maybe scrub in that will give the carpet protection from fade.
To recommend excellent fitting carpet package please
