ECM Code 15
Old Apr 25, 2017 | 10:37 AM
spro2395's Avatar
spro2395
Default ECM Code 15
My 85 just started showing code 15 and at the same time the main cooling fan starts. This happens when the engine is cold. Are the 2 related?
​​​​​​​Thanks
Old Apr 25, 2017 | 10:52 AM
belairbrian's Avatar
belairbrian
I think so
iirc 15 is a coolant temp sensor error
so the fans are turned on to protect the engine
Old Apr 25, 2017 | 11:31 AM
spro2395's Avatar
spro2395
Originally Posted by belairbrian
I think so
​​​​​​​Bad sensor then ?
Old Apr 25, 2017 | 08:55 PM
spro2395's Avatar
spro2395
OK I found a flow chart for code 15 and I'm stuck at the part probe yellow wire with a voltmeter and I got .5 volts which is OK. It says Sensor ground circuit open, faulty ecm conn or ecm. How should I proceed? Electrical is above my skill level. .
Old Apr 25, 2017 | 09:12 PM
WVZR-1's Avatar
WVZR-1
I don't believe I've ever seen anything in CODE 15 diagnostics that mentions .5V as being a "good/expected" value.
Have you actually checked the CTS resistance values for the engine when at running temperature.
I'm assuming you're at FIG 32 of the FSM. Is that correct? Check the resistance of the CTS using the chart in FIG 32
If the engine is COLD check it cold then maybe start and run to something near the expected run temperature and check.
Old Apr 26, 2017 | 07:17 AM
spro2395's Avatar
spro2395
Yeah. Bad eyes, I thought it read .5 when really it's 4-6 volts so the reading I got of .5 is low. Yes I'm looking at Fig 32 in my FSM
​​​​​​​So I feel like this might be over my ability but hopefully not!
To ECM Code 15
