89 fx3 owners. feedback?
i think thats what brandons beast got.
anyway, im researching options in that year and im curious about the fx3 suspension.
is this a good option or more of a hassle than its worth in the 89 year? like early version needed bugs worked out type thing?
My opinion, if it is an option on my car, I want it to work. That being said, I added it to a car. No complaints.
You could retrofit FX3 into a car that did not come that way, but it will be a lot of work and you have to find a way to update the CCM (body computer) so it will work properly. The CCM also provides the error codes for the FX3 system. Then there is the wiring harness, the processor (fits behind the driver's seat in the compartment where the ABS stuff is located). Then you have to find the shocks and actuators. There are two versions of shocks based on the year of car.
I had read last year that Bilstein can no longer rebuild or repair the rear shocks as they are out of parts. New shocks are expensive as are new actuators. Do a search on "FX3" and you should be able to find sources for rebuilt actuators or new/used shocks.
It's been a long time ago , but a former CF member worked with Bilstein to build a custom valving setup called "Moracca" or something similar that was a big help for autocrossers and track guys. You sent your FX3 shocks to Bilstein in California asking to have them custom built to those specs.
I think there are a variety of excellent shocks, springs, and sway bars available for the C4 that it would be much cheaper to go that way and easier to install.
The only tie in that is for the CCM is the speed input and that is a splice directly off the VSS line. The Ride control system is a completely independent system just like the ABS is. It requires no instruction or input from the CCM.
The CCM does not provide the error codes. The Ride Control module sends the error codes when you ground the correct pin on the ALDL.
