firewall pass through locations
Old May 3, 2017 | 01:20 PM
Buick350X's Avatar
Buick350X
Default firewall pass through locations
Could not really see any, are there any pass through location factory that can be used for a few wires.
Or do you have to start drilling holes?
And where is the best location to drill or run wires?
Old May 3, 2017 | 01:49 PM
383vett's Avatar
383vett
My firewall looks like swiss cheese.
Old May 3, 2017 | 02:11 PM
vader86's Avatar
vader86
You can try running through the hole that the hood release cable runs through. Its run through a thick rubber grommet that you can remove, kind of a pain to get it back in there right though.
Old May 3, 2017 | 03:39 PM
Hot Rod Roy's Avatar
Hot Rod Roy
What are you trying to do? What year 'vette? There are a few wires that already loop thru the C110/C115 firewall connectors.
Old May 3, 2017 | 04:23 PM
Buick350X's Avatar
Buick350X
wanna get the light bar n wench hook up for muddin...
Old May 3, 2017 | 07:44 PM
Hot Rod Roy
My wench usually rides shotgun! We don't much care for the bar-hoppin' scene, though.
Old May 4, 2017 | 10:43 PM
A Peter C4's Avatar
A Peter C4
You are going mudding in your Corvette and will need a winch? Just lock the front hubs and run swamper tires you should be good.
Old May 5, 2017 | 06:25 PM
Buick350X's Avatar
Buick350X
I find looking down at the dash to check RPM takes eyes off the road to long, as I haven't had it long enough to just glance.
Thought of putting a mini shift like some where, maybe 2 [blue,red light].
Blue will be at peek power for banging gears, the other will be just before redline- ish.
I dunno really just brain storming. Just don't want a big tach mounted somewhere.
A simple thin line LED tach, like an in tall 3-4 in wide I can see looking straight forwards.....................
Old May 5, 2017 | 09:59 PM
Patsgarage's Avatar
Patsgarage
I did a quick Google and did not come up with anything, but there are progressive shift lights for OBD II cars. Someone out there might offer something like that for OBD I as well.
Old May 5, 2017 | 10:34 PM
Buick350X's Avatar
Buick350X
maybe if I can find a adjustable shift light cheap with good reviews, I could just hide it and extend the light to be just some where visual. Not the whole thing./\.
Old May 6, 2017 | 04:05 PM
Buick350X's Avatar
Buick350X
the hood cable does look promising, as of now where I like the wheel, I can only see up to 2500 rpm on the curve, can't see the rest or the square.
Did notice in the defrost vent, there is a square pad area where the screw goes, where 2-3in mini tach could sit.....
Old May 6, 2017 | 10:22 PM
A Peter C4's Avatar
A Peter C4
Summit raceing adjustable shift light $45,Auto Meter $55 No tach,just shift light.
Old May 7, 2017 | 08:42 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
Does this help you any ? The harness pass thru's are marked as "P_ _ _" ( blank spaces indicate 3 digit number )
Old May 9, 2017 | 02:43 AM
Hot Rod Roy
Like this?
Old May 9, 2017 | 02:32 PM
Patsgarage's Avatar
Patsgarage
Originally Posted by Hot Rod Roy
Like this?
0.25 extra shipping East of the Mississippi.
Old May 16, 2017 | 10:27 PM
Buick350X's Avatar
Buick350X
I got the 2in round tach I ordered. No way in heck will it fit where I want. Its BIG for 2in. I really expect it might be to small, or hard to see.
so I need a 1in tach
Old May 16, 2017 | 11:57 PM
A Peter C4's Avatar
A Peter C4
Auto Meter makes several actual 2" tachs that fit in a standard 2' gauge panel, single gauge cup or even in a A piller pod. Check Summit Racing. They also had a couple Hardrive brand Mini style that looked about 1 7/8 dia. total, with bracket.
To firewall pass through locations
Old May 17, 2017 | 05:12 PM
Buick350X's Avatar
Buick350X
Well I found a factory 2in hole, just need a little filler square...
Old May 17, 2017 | 10:22 PM
A Peter C4's Avatar
A Peter C4
There you go.
Old May 18, 2017 | 01:04 PM
Buick350X's Avatar
Buick350X
So ive been just going​ by feel since I can't see. holey crap its even faster then i thought. Ive been shifting just before 3000 goin by feel. Only got a short drive as im gonna need allot more road to test
