Mobil One
you seem to talk out of both sides of your face. you take insignificant comments, and turn things into some sort of pissing contest. yes, this is an open forum, but personally, i'm tired of dealing with you. my friend, you're just not worth the keystrokes.
finally, as to the number 5, you said you're not sure what it means. well, let me clarify the units - IT'S THE IGNORE LIST!
...have a good one!
To me it is not worth the hassle of sending an oil sample for analysis when it is so cheap to just change it. How long you can try to keep oil in the engine is not a priority for me, so I generally follow the manufacturer's and oil manufacturer's recommendations of at least change yearly. Cheap and easy.
that i'm throwing my money down the toilet, and somehow i'm gullible, yet you seem to justify spending money on a lap dance, and somehow, that's not throwing your money down the $hitter. in another thread, you stated;
a bit excessive. how do you know these parts and fluids are worn out? are you doing some sort of scientific, laboratory testing? seems excessive to me, and probably, 99% of the folks here. so where's the investment? just think, you could do it every two years, save $60, and get yourself another lap dance. now. there's an investment -
...have a good one!
Again, I showed you my numbers as to how I arrived at the conclusion. I haven't seen much except vitriol. Further to that, if you can consider getting dirty and wasting time disposing oil, etc "therapy", I think I would be entitled to consider a lap dance "therapy", no?
The plugs I buy are not the highly expensive ones. As to the cap and rotor, if I don't change it in spring, my May or June, there seems to be a miss at WOT that magically is cured by a new cap and rotor. The old ones I have tried cleaning the boogers off but not much life before a new cap is necessary. Plug inspection lets me know if it is burning oil or coolant BEFORE it gets too bad. And yes, I have tested gear oil and trans fluid before by a lab. Point?
And yet you spent all that time researching my previous posts? Who's talking out of both sides of their mouth now, my friend? (PS, that salutation has a hidden message)
If it was the ignore list, how did you see it? Oh, that's right. You wanted a drama situation. Never mind, how silly I missed that. But just to be sure, my usual rule of thumb is "If you aren't having sex with me or writing my check, your opinion don't matter." and I wanted to make sure before I hit it with that big a brush. What should my reaction to being #5 or put on your ignore list be? Sadness? Feeling lost? Do I need to start therapy? (Please say no because IMO, therapy is kinda of a scam)
So, today an analysis is $28. Isn't it cheap insurance to see if the motor is worthy of the time and money BEFORE you do it? Now you have to do it AGAIN and that first time money is down the drain. Lets say you were me. Some guy comes up to you and says "For $50, I will tell you if the motor is on the way out or not BEFORE you spend money for a professional install on heads, cam and tuning.". What would YOU do?
BTW, if I found that out today, sure, I'd beat the hell out of the motor in the last days but NFW would I drive that car out of town. I changed the trans fluid in my old car because it was slipping, drove it 6 hours away because we were doing a few job interviews in the city we were moving to. I think you can figure out what happened. I think you will believe me when the said that the service guy says "Well, this is the price for a rebuild. That or tow it out of my yard. Bend over and no lube for you.".
http://www.blackstone-labs.com/report-explanation.php
However, to judge whether the oil needs changing or how long you can run the oil, I think it is a waste.
Last time I used a clean item was to boil the meat off the skull cap around the deer horn and the wife was NOT thrilled at me using her favorite pot. If I used her soup pot, I might not be back to report the findings. Not alive anyways.
