Can't reset the oil change reminder light
I changed my oil and filter today. Now I can't get the oil change light to reset. I've followed instructions in the manual, but it stays on solid. I tried disconnecting the battery for 30 minutes, no luck. What the heck? 93 Coupe.
That's what I thought so I went on utube. Turn key on, don't start. Press eng met twice then press gauges button. Supposed to flash then go out
Read This and make sure your performing all the steps correctly.
https://www.corvetteforum.com/forums...oil-light.html
You have to hold the gauges button. Don't just press it.
If that doesn't work, I would guess one of the buttons is not working, or you aren't pressing firmly.
The ENG MET button doesn't do anything with the engine running or off. I took that piece of the console off to work on the radio and bypass the Bose speakers.
