Added another C4 to my....(ahem) "collection"
#221
Looks much more modern with the headlights, what are those from? Looks like 90s Dodge Stratus?
#223
Pro Mechanic
Thanks!
Huh. I'm not sure how I could get the amber plastic lens out w/o ruining the assembly....but I'll look at it tonight.
Thanks. Excellent guess! The Stratus headlights are a bit taller and bulkier than these. These were the thinnest/smallest all-in-one housings that I was able to find at the yard I looked at. They're from a Chrysler Cirrus.
#224
Thanks!
Thanks. Excellent guess! They Stratus headlights are a bit taller and bulkier than these. These were the thinnest/smallest all-in-one housings that I was able to find at the yard I looked at. They're from a Chrysler Cirrus.
#226
Finally, when I bought the car, the PO went on and on about how much he looooooooooved his '89 Corvette and how he didn't want to sell it but knew that he couldn't fix it. For his claim of love...he sure didn't maintain it too well. Damn....how about an oil change now and then? It's going to take a lot of oil changes to clean that out. The sludge is about 1 cm deep...everywhere.
#228
Pro Mechanic
Ha ha ha ha!! Yep, I had that one coming! I actually joked w/a friend of mine yesterday; "How many gallons of Seafoam should I pour though this engine?" -I asked him. He laughed out loud.
Not that I'm going to use Seafoam....b/c I'm not, but THIS would be when one might use a product or additive; when there is an actual problem that needs addressing, and we have the right product to do that. I'm just going to use oil changes.
#229
Agreed! A few oil changes and a quality filter will do wonders for that. Valvoline Maxlife (semi/syn maroon bottle) might be a good choice for that L98. I use it in nearly everything, they love it over on BobIsTheOilGuy forum.
#230
Pro Mechanic
: Right on. Thanks for the tip.
#231
Besides, everyone knows marvel works better than seafoam anyway.
#232
Pro Mechanic
FINALLY got the front harness and headlight wiring done. Damn that took a while. Well it took a day...but it took a while for me to patch together enough time segments to make one day's worth of work. Anyway, here are some random pics of various stages of playing with spaghetti....
Here I'm putting loom on the first headlight harness...
This is the entire "front" harness; fan wires, headlight hi/lo, turn signal, horn and parking light...all stuffed into that neat little 1/4" loom.
These are the completed headlight/corner light harnesses...
Finishing that was, of course, occasion for another..."test drive".
#233
Pro Mechanic
Another small, but meaningful milestone!
#234
Wish you many miles of smiles in your new cart!
#236
Can I make a suggestion? It looks like your battery is exposed in the front. You may want to put a piece of sheet metal there to keep something from being thrown up and puncturing your battery.
Keep going, the build has been sweet to follow!
#238
Pro Mechanic
Thanks guys! Yes, it was a relief to get it "official" finally, even though in the end, it was no big deal. I "worried about **** that ain't worryin' about"!
jsmcol; I'll think about a battery protector, but the batter base is about even with the bottom of the floor pan. The exhaust runs right between it and the rear wall...so the likelihood of something getting up in there is pretty darn slim. Good spotting/thinking though!
BIG DAY TODAY!! Today was Park City Cars & Coffee. I'd sort of set today as a target for getting the reg/insurance/plate mounted and rear lighting done and driving it somewhere (to C&C). I wanted to take it to C&C and my boy really wanted to go in the Kart, too. By yesterday, I had everything done but the rear lights. I worked on that pretty late last night, but didn't finish. I got up early this AM and resumed work; I still had to finish fabricating one light mount, then build the rear harness -only 4 wires really, but still, you gotta get all the lengths right, solder and shrink wrap parts of it, loom it, bracket the loom, install connectors, etc. I was doing great, until about the moment we were supposed to be leaving for C&C. All I had left was about 8 minutes of work: cut the tail light pig tails (they came with a connector on both ends, one end I wasn't going to use) and solder/shrink wrap the pig tail/connector for the light, to the harness. Aaaaand I was a f'n DUMB *** and cut the wrong connector off the pig tail. I cut the f'n connector off the wires that plugs into the tail light! What an idiot. I swear....sometimes....
It was a connector like this one -the male/one on the right:
Of course, wanting "extra" wire, I'd cut ^that^ connector that I needed off the pigtail right at the connector, so I had nothing to work with. I can not tell you how f'n livid I was with myself. Man I was furious. How in the hell was I going to rectify this?? I wasn't. The day/goal was shot, by complete idiocy. Sometimes, it sucks being a dumbass.
I wanted to go to C&C....and I got us SO close. My son wanted to go...he was bummed. I took the two connectors that I needed -that I'd chopped the wires off down to ~1/8" stubs, and I got out my Dremel. I chopped off the rear 1/4" of the connector housing, which revealed more wire...about 1 cm. I braided that eeny teeny bit together with the harness, soldered then shrink wrapped it...3 wires on each side/connector, successfully. Plugged the two connectors into the tail lights, had my boy step on the brake pedal -we had brake lights. Parking lights? Boom, on they came too. HOT DIGGITY DOG. I threw all my **** on the work bench, hopped in the car and headed for PC C&C at about 10 AM (wanted to be there at 9, but it goes until about 11). Anyway, here are some pics of the tail light mounts that I built....
#239
Pro Mechanic
Anyway, on to C&C. It was fun. There were two noteworthy things about this:
1. The Kart is about 1000 times more interesting to people, than a nice '92 LT1 red Corvette. Why? I mean it's different but no one at Park City cars & coffee GAF about a '92 'Vette. But people were all over this thing, the whole time. Even when I was trying to leave people were asking questions and grouping around the car. So it was cool that people were interested in the car. There are a ton of things that you could pick apart and make fun of, on the thing...but I didn't overhear anyone saying much in that regard.
2. On my drive home, I drove right past a Summit County Sheriff sitting beside the road. I thought, "this will be an indicator as to whether or not I can drive this thing on the street or not!". The guy didn't even pull out. I just drove on by and everything was cool NICE. And I still need a windshield and mirrors. I think I have everything else covered.
OH....I almost forgot. Car ran flawlessly. Now that I've gotten it out on the road, I can see how it could use more power. By 4th gear, it goes from "amusement park ride" down to "fastish car".
Here are a few pics of the morning....
Driving there. It's weird...there is very little wind in your face. For some reason, the vast majority of the air goes up and over you.
^That would NEVER happen with my '92. No way, no how, not happening. Oh! the rest of the cars there were "meh". A Ford GT is worth mentioning. A really nice Factory Five Cobra, otherwise it was an onslaught of Porsches and BMW's and OMG are those Porsches annoying. They all have a ton of 'tude and they all have loud exhaust. Know what a 911 sounds like with PDK and a lound exahust? It ain't good. Braaaaaaa (shift). FART!...braaaaaaa, FART . The coolest car there today though??.....Hardcastle and McCormick came today with the Coyote!!!
#240
Awesome man.
