Disappointing Beginnings
After a week of tests (and 2 different mechanics) the fuel pump was identified as the issue. Mind you, prior to buying the car, it had the spark plugs, spark wires, distributor cap all replaced. Now the fuel pump and filter replaced. It drove fine for a week after I got it back.
This week I intended to finally get all fluids & filters flushed & redone when the car starts acting weird. After driving on the interstate, "Service Engine Soon" light hits and the car makes a strange ticking sound while moving - like when a playing card flaps against a bicycle wheel. It had a burning/chemical-y smell from the driver's side of the engine (exterior smelled, not interior).
Next day when I start it, white smoke blows out of the exhaust. Only upon startup, but the car still smells bad. Like chemical/coolant smell and strong gas smell. Coolant level looks low but the info system isn't warning me yet. Oil doesn't look milky but car has a small puddle after driving. *summon eye-rolls*
I'm thoroughly annoyed. I knew buying an older car meant it would require updates, but come on. I've barely been able to drive it. Now I'm worried I have a busted head gasket after paying a premium for a car I thought had been repaired. I don't even know if I can afford to pay to fix the head gasket after dropping all the cash on purchasing the car itself. Is this typical? Do these cars break down a lot, or what??
If you think a head gasket job on a car is a nightmare, try dealing with one on a diesel. I baby my Duramax (meaning don't run the engine hard before it warms up, let it sit and idle down, don't push the Horsepower Up Button on the computer to the level it could lift the heads) as I have one of the ones that were before a design change to the head gaskets.
I could go buy that 94 M6 out by Youngstown for what it costs to pay a shop to do them. $5000.00 minimum. If you go with ARP studs instead of GM's crappy torque to yield bolts, the parts alone are $1000.00'ish and that is if you don't break something taking it apart.
And yes I have done SBC head gaskets. Not a big deal. Just read the directions and ask for help if need be. And if you invest in a good set of tools, fixing the rest of the issues that pop up won't be such an ordeal.
I'm thoroughly annoyed. I knew buying an older car meant it would require updates, but come on. Now I'm worried I have a busted head gasket after paying a premium for a car I thought had been repaired. I don't even know if I can afford to pay to fix the head gasket after dropping all the cash on purchasing the car itself. Is this typical? Do these cars break down a lot, or what??
Yeah, this is probably pretty typical. It's not typical for MY car...but I'm totally on top of my own car's maintenance...I KNOW what is going on w/it all the time and as a consequence, I end up repairing it before it breaks.
The reality is, you either need to be well funded to pay for an old car's maintenance, or you have to get intimate w/it, and do it all yourself.
Sorry that you're having troubles...my recommendation is to roll up your sleeves and have a relationship w/your own car.
Like I said, I expected the car would need work because I get that it's a 31 year old car. But I was told by the dealership I bought it from that it had been through a mechanical reconditioning process and I knew about the spark plug/wiring work. So now the car has 2, possibly a 3rd major repair and I've owned it for three weeks. That's why I'm pissy. I've driven this thing less than 10 times. I didn't expect it to break down every single week the first month of ownership. I thought I could get at least 1 season in before the major repairs started. This would be a different story if I'd bought it from an honest seller for an honest price as a "fixer upper."
You got the dealership experience, unfortunately. See if you can buy a Carmax or similar used car warranty; then you costs will be fixed/managed and you can enjoy the car more, perhaps.
Its always a crap shoot when buying an older car, even more so with a Corvette... I've had 8 now, and I know things needed attention on all of them.
I used to turn wrenches for a living, so I wasn't really afraid of repairs. I'm now older and really don't want any major repairs to deal with. I bought a 34,000 mile 86 last month... from a Forum Member like pretty much all of my Vettes. The car was in as advertised condition (excellent).... That said, even with the low miles, I needed to do brakes, valve cover gaskets and shocks (this week), I know it will also need fuel injectors soon.... Its just the nature of the beast. Old cars = $$$
You need to do some foot work before buying one of these cars. Ask the right questions and read allot about the different trials and tribulations of others who've been through it.
You're in now.... so either you will need to start learning how to turn wrenches and buy some tools, or pay to fix it, sell it and cut your loses... Old Corvettes aren't for everyone. If you do sell it, I would consider a C5. LS engines are much newer and there are shops that will be able to diagnose and work on them.
Good Luck with whatever you do....
I'm waiting to see what a mechanic says when I take my car to one on Wednesday. I'm worried this thing will be in the shop more than I get to drive it. I wanted a daily driver (for non-winter use of course). Maybe it just has a lot of neglected areas to address before its back to being relatively "normal."
If I'd bought a $5,000 car under the presumption that I needed to tackle lots of repairs, that would be more fair in my mind. If I'd bought what I would have considered the "perfect" Vette, it was pristine and pretty and "worth it," then that would also be a different story. But this is honestly not the most special Corvette out there, and I'm annoyed that it's going to be a money pit when it never fully crossed everything off my wish list.
Next time you buy a used car. take it on a good test drive. For all that **** to happen within three weeks and not many miles, I bet something was wrong before you even cranked it up.
The day I bought, I test drove the car for a couple of hours. It was fine during that test drive. I was confident enough in it to plop down the cash for the car. The dealer isn't super reputable and is a used-car-only place. Their mechanic was kind of a jerk but I guess it would send a message if I brought the car back in again... ha.
I felt bad for ******* on my car so I did the bare-minimum of "repairs" and tightened all the loose phillips screws in the car.
That much I know how to do. Turns out the components near the hatch were loose and preventing it from releasing, so now that's fixed. I imagine it will squeak and rattle a tiny bit less from my interior tightening. It is special to me because it's finally my first Vette, as much of a problem child as it seems to be....I'll just have to put up the funds the repairs require and get a FSM in the meantime. Big picture is I got the biggest cost -the initial purchase- out of the way. The first thing I bought for the car was its build sheet, guess I had my priorities mixed up. Time to watch some YT videos and learn....
There's three options.
1) Fix it.
2) Dump it.
3) Make lemonade with life's lemons, like mom used to tell us.
If you wanna do the third, it's a great opportunity to add a cam and some heads.
I put these on mine and I like them a lot.
http://sdparts.com/i-23896057-sdpc-s...baseplate.html
Also, a set of rebuilt injectors from FIC.
It's a 30 year old car and it's not running good even when you think it is.
I know it is disappointing, (Trust me on meandering aimlessly through the C4 stages of grief!) but if you take the opportunity to do some upgrades and fix it better than new, then you can really enjoy it!
I'm thrilled now.. But I sure wasn't that afternoon I was sitting there with it blowing coolant everywhere.
Every C4 I buy does need work. I prefer it that way so that I can sort the car out and get it where I want and learn the car thoroughly. The current one I own gave me a little buyers remorse after the initial purchase but I really like the car now and enjoy driving it. I still want another 84, but the 86 fills my heart.
The C4's are generally pretty reliable as long as the maintenance is kept up and the fluids checked. It sounds to me like your car does need some attention. Whatever I can do to help let me know. The C4 is a fantastic car and its really a bummer to see your first C4 breaking on you. If you do sell this car and buy another one in the future, buy from someone that collects them and maintains them. A true Corvette enthusiast.
Unless you are a wealthy person, unless you learn to fix it yourself (there are a few things that you need specialized equipment for, such as servicing an AC system, alignments (for the most part) and would pay someone to do) you might as well cut your losses now and trade it in on a c5 or newer vehicle that is going to take less maintenance.
No one above is being a d*ck saying that. It is just the truth.
BUT learning to work on the cars is not that hard, unless you have a mental block that you can't or won't do it.
Same here. I do transmission and driveline for a living, (Not a Vette mechanic) but I'm about an hour east of you, and if I can answer questions or help in any way, just PM me and I will try to get you through it to the best of my ability.
I hate to see you stuck.
I think I have found a one-of-a-kind mechanic that I can trust who won't bankrupt me. My cousin out of town is also a mechanic, so if the guy I'm taking it to this week fails me, I'll drive up to my cousin's shop next. Hopefully he won't bankrupt me either
. I also understand the value of paying for a service. Yeah, you can do things by yourself but if you don't know what you're doing, is it really a good idea?If I had any experience whatsoever working on cars, then I would totally hop out in my garage and get to tinkering. Of the last 3 cars I've owned, I never once looked at the engine/popped the hood. Didn't need to. I have never opened the oil cap on an engine until I checked mine on my Corvette the other day. I had to google what oil is supposed to look like. I don't know anything!!
If I'd had the money to afford a C5, C6, C7 I might have considered it. Perhaps when I no longer have a lease as my DD, draining my bank account, I'll consider a more expensive/newer Vette that I can get a loan for. But I don't like the C5 body style, never have, and the C6 is not much different to me. It will be quite some time before I can afford a C7. I've always loved the C4 and still do.
