Under hood lights
Old May 15, 2017 | 01:37 AM
Stephen Alcorn's Avatar
Stephen Alcorn
4th Gear
Default Under hood lights
I recently purchased a 93 c4 and one of the lights under the hood was loose and the screw wouldn't come out or tighten, so I took out the opposite screw and tried to see how I was going to fix it and I was about to have to go to work soon and was running out of time so I tried to put the screw back in and now both freaking screws are barely holding this thing in the hood and wont tighten or come out, I would love to get this thing fixed ugh !
Old May 15, 2017 | 02:34 PM
belairbrian's Avatar
belairbrian
I'd suggest looking at u-nuts.
Old May 16, 2017 | 05:40 PM
don hall's Avatar
don hall
My humble suggestion is to remove the screws while holding the glass before the glass falls and breaks. The glass is not a cheap item to replace.
Locate some sheet metal screws, or self-tapping screws, that will secure the glass....... any parts store has them.
Take one of the old screws with you to compare size to the new screws.
Old May 16, 2017 | 07:57 PM
BLUDICE's Avatar
BLUDICE
Remove screws - fill holes with JB Weld - re- install original screws. BTW always keep JB Weld in your garage tool box - has a million and one uses.
To Under hood lights
