Emergency brake handle problem
Old May 15, 2017 | 08:53 PM
Torx40's Avatar
Torx40
Default Emergency brake handle problem
My 94 coupe's emergency brake handle is inoperable. It will lift and has breaking action but the ratchet mechanism does not work.. Not sure if this is common problem.. Is this an easy fix? Just thought I'd ask before tearing into it on my own.
Old May 15, 2017 | 09:13 PM
Patsgarage's Avatar
Patsgarage
It sounds like the release button is stuck an not allowing the brake to lock in place. If it is like my 89 you have to remove the drivers seat (very easy) and then you can remove the cover to get a better look at the mechanism.
