Front right caliper binding
Old May 16, 2017 | 05:56 PM
mrvvince's Avatar
mrvvince
2nd Gear
Default Front right caliper binding
I have an 87 Vette. The passenger side front caliper is not releasing. I have replaced both front calipers, brake lines and disks, with no resolution. I brought the caliper bake to where I bought it thinking that the replacement was bad, no such luck. I finally brought it to a dealer where they checked the master cylinder, ABS system, speed sensor and concluded it was the caliper. They replaced the caliper with a GM original part and did not find the resolution. They called me and told me to come and get the car and that they could not find the problem. Any Ideas????
Vince
Old May 16, 2017 | 11:39 PM
ex-x-fire's Avatar
ex-x-fire
With the bleeder open does it still drag? If yes then its the caliper, if no then follow the line back till you can loosen a connection that releases the caliper. Go to the abs module & loosen that connection.
My guess is the abs module is giving a little pressure to that dragging caliper.
