Tires
Old May 27, 2017 | 03:28 PM
monte k's Avatar
monte k
Default Tires
I currently have a 1984 corvette with 16 inch wheels
im thinking of changing to stock 1989 corvette 17 inch wheels
will I need a spacer or other modifications
thanks
monte k
Anderson , IN
Old May 27, 2017 | 04:41 PM
c4cruiser's Avatar
c4cruiser
You will need adapters that are 18mm or 3/4" thick to get the OEM '89 wheels to fit properly. The '89 tire size (275/40-17) are nearly identical in overall size to the '84 255/50-16 tires so you will not see a difference in the speedometer reading. Tread width will be very close to the same too.
Old May 27, 2017 | 06:22 PM
monte k's Avatar
monte k
Thanks cruiser
To Tires
