Engine stall
Old Jun 2, 2017 | 05:56 PM
Zoomie860's Avatar
Zoomie860
Cruising
Default Engine stall
Took my 92 vette coupe for a spin last night and accelerating thru 45 mph the engine just quit! Coasted, threw it in neutral and hit the starter, 2 tries later in fired and I turned around and headed for home! Any thoughts on where and what to look for? I've only had it out on the road twice so far since winter broke. Thanks
Old Jun 2, 2017 | 07:25 PM
pologreen1's Avatar
pologreen1
Just died or slowly died?
-Check battery cable connections
-Check fuel pressure at the rail and fuel filter
-fuel pumps do die on these but real easy to change right at the gas filler
Old Jun 2, 2017 | 11:14 PM
Zoomie860's Avatar
Zoomie860
Cruising
[QUOTE=pologreen1;1594867217]Just died or slowly died?
-fuel pumps do die on these but real easy to change right at the gas filler[/
It dropped dead! No missing, no sputtering, no warning. But then for it to start right back up while I was drifting at 40 mph.
You thinking more fuel than electrical problem. New fuel pump was put in last year and at the end of last summer them fuel pressure was checked for a bad miss that was a #5'fuel injector gone bad.
Old Jun 2, 2017 | 11:57 PM
pologreen1's Avatar
pologreen1
[QUOTE=Zoomie860;1594868350]
Okay, so the fuel system has been worked on. That means it is either taken care of or possibly not done right.
More than likely than it is electrical connections or even computer then, but I really doubt the computer.
I know I have a small wire on mine that is connected to my positive on the car battery and it was once cracked and causing major no run conditions. These things are old now check wires.
Probably best to research the optispark too in case that is your issue.
To Engine stall
