Some suspension before & after photos
Old 06-18-2017, 08:07 AM
jpipx
jpipx's Avatar
Originally Posted by Robert Blakeney
Guys, given the already stiff ride on the C4 what are you experiencing with the new stiffer bushings? Would fresh stock bushings be better to replicate an original ride?
That work is purdey!
I can say with confidence and experience that the ride is much more "predictable" when going into curves. The old rubber was so dried out on the car had a tendency to roll through curves instead of engaging them. Besides that I haven't seen any stock rubber bushings around any more.
Old 06-18-2017, 08:09 AM
jpipx
jpipx's Avatar
Originally Posted by HAD2HAV2
How did you refurbish the front and rear inner fender panels?
I cleaned them down with a mild solvent, repainted all of the bolt heads and applied some plastic re-conditioner after reassembly.
HAD2HAV2 (06-20-2017)
Old 06-20-2017, 03:09 AM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Robert, if you'll check, OEM rubber bushings are not currently available.
Seems the C4 just isn't in the re-poppers sights yet.
So until someone starts, the only option is aftermarket "nylon" style bushing.
And the conversion, if executed properly, is not much change from stock.
The car is more responsive to driver inputs.
Just remember that the C4 reintroducted the Corvette as a fast car.
Not from the slug it became as the 70's closed.
Old 06-24-2017, 07:39 PM
rblakeney
rblakeney's Avatar
Thanks! Didn't know about the stock availability. I am assuming that even within the various non-rubber alternatives some are harder than others - true? My 89 has the FX3 system anyway so I can probably get to a happy spot on the cushy cruise days.
Old 06-25-2017, 10:45 AM
maddogwyatt
maddogwyatt's Avatar
Mine is now polypushed throughout, and although the ride is still very firm, it doesn't crash into potholes so badly, and is SO MUCH more positive due to the wheels staying where they're supposed to!!
Old 06-27-2017, 05:20 AM
gerardvg
gerardvg's Avatar
Yes i recently replaced all my rubber bushings and i hate the stiffer more bouncy ride, you cannot get rubber bushes anymore.
The rear is the main issue the 4x dog bones then the strut rods, the issue is the crush tubes are a firm fit.
Even though plenty of the special grease was used the crush pins are very tight in the poly bushes, on a smooth highway its not too bad however i went on a long trip on very average roads and the ride so harsh over the road irregularities and slight bumps.
I am tempted to go to a wrecking yard to fine some second hand c4 dog bones with good rubber bushes.......
Needles to say the little woman will not get into the c4 for road trips again ......
Great for track use, like having at least 50% stiffer springs.
Old 06-27-2017, 12:12 PM
DMITTZ
DMITTZ's Avatar
Great work on the suspension refresh OP, you did a great job!
jpipx (07-01-2017)
Quick Reply: Some suspension before & after photos
