1985 Brake Problem
Old Jun 16, 2017 | 08:31 PM
Larry Hargrove's Avatar
Larry Hargrove
Default 1985 Brake Problem
I've got a brake problem and a brake question. First I recently bought a 1985 and the brakes were pretty good. Now when I step on the brake the pedal continues to travel downward. There is resistance but it doesn't stop.If I let off and press it again it is better but not like it should be. I can't find a leak anywhere. One of the fluid bowls is about half full and the other is full. I mean full to the point of flowing over the top if I take the top off. I suspect the master cylinder is bypassing. Yes or no. Secondly, how can I tell if the brakes are original equipment. With a car that's 32 years old you never know what changes previous owners have made.
Old Jun 16, 2017 | 08:41 PM
xrav22's Avatar
xrav22
The bowls have marks and they are the same. Sounds like you need a master cyl. You can reuse the bowls in some cases. Inspect the brake pads if they are low change them out anyway.
Good luck.
Old Jun 16, 2017 | 09:04 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Your rubber brake hoses may be old and swelling up when you step on the pedal. Have them inspected by someone who knows what they are doing.
Old Jun 16, 2017 | 10:30 PM
John A. Marker's Avatar
John A. Marker
with xrav22....you need new master cylinder. The brake fluid is seeping around the seals in the master cylinder. The rubber brake lines with age will bulge a little when pressure is applied to the brake, but you will still stop. Brake would feel a little spongy. I would suggest that when you change the MC you replace the rubber brake lines with stainless steel lines.
Old Jun 17, 2017 | 02:46 PM
ghoastrider1's Avatar
ghoastrider1
if you know your way around a wrench, they sell rebuild kits for that master cycl.
Old Jun 18, 2017 | 09:01 PM
gerardvg's Avatar
gerardvg
Master cylinder, Bleed the brakes to be sure.
I replaced my master cylinder a few weeks ago, brake fluid was bypassing the seals.
The pedal was fine at first application however would slowly go down, while waiting at traffic lights.
Be sure to bleed the brakes first to ensure there is no air in the brake lines.
See below what I got, the master cylinder bleeding kit prior to fitting to car is handy
http://www.ebay.com/itm/Brake-Master...lZMciM&vxp=mtr
To 1985 Brake Problem
