C4 Quirks
Secondly, because I am so tall the steering wheel hits my knees when I shift. Has anyone lengthened the steering column on a C4? Anything I should know about wiring, etc.?
Thanks.
John Vowell
Fort Myers, FL
the steering column...yeah not sure your in luck there. I'm 5'11 and even with the wheel tilted up as far as it goes, i hit my knees when getting in/out of the car. i dont however have issues with shifting gears...i highly doubt you can safely mod the steering column. You can do what I'm going to do though...I'm shopping for an automatic LT1 car for my regular around-town driving because the 6-speed is a pain (i'll keep that for the open road driving).
good luck and do that simple trouble shoot on the switch. something does sound a little strange though...you replaced the switch but the switch was bad as well? that seems like really bad luck or an issue somewhere down the electrical line. you may need to remove the kick panels and console covers (to get full access to the wiring harness for the console mounted switches) and perform some tests with a volt meter
