Water Pump
Old Jun 17, 2017 | 12:03 PM
funbooker's Avatar
funbooker
Default Water Pump
Hi,
I've been chasing a high temperature problem with my LT1, 93, C4. I have replaced the radiator because it blew out. I have done multiple flushes, replaced all the hoses and pressure tested.
Lately, the dashboard temp gauge stays around half, most of the time. If it sits idling for more than a few minutes when it's hot, it will creep up almost all the way to the top of the gauge. It comes back down when I run the heater or begin driving.
I used to see a stream of water coming out of the side of the top tank when I had the cap off. Now I don't. In fact, when it's running I don't see any movement in the tank at all, which leads me to believe the water pump may not be circulating coolant.
I replaced the pump a few years ago but it has probably been more years than I remember. Should I see coolant moving when I take the cap off the tank? I really don't want to tear down the pump just to find out it's working fine.
Thanks in advance
Old Jun 17, 2017 | 01:44 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Originally Posted by funbooker
Hi,
Thanks in advance
Are your fans turning on? What does the digital temp say?
If your water pump wasn't working, your car would over heat vary fast.
Old Jun 17, 2017 | 03:57 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
you sure you didn't mix up the coolant hoses? is your rad cap good?
Old Jun 18, 2017 | 01:01 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Have you checked the coolant tank and checked the lines in and out are clear? When you did the coolant flush did you pull the knock sensors on the block and poke around the openings to clean out the scale so all the coolant came out?
Old Jun 18, 2017 | 08:24 AM
jpipx's Avatar
jpipx
Hi,
Thanks in advance
Possibly air bubbles stuck in the high point restricting flow? Did you bleed from the thermostat cover bleeder screw?
Old Jun 18, 2017 | 11:31 AM
mickey5's Avatar
mickey5
If the temp stays in the mid range when driving and warmed up you should be ok. When standing still the temp should rise to about 235-240 when the fans should turn on and bring the temp back down to mid range. It sounds like your fans aren't working if the heater brings it down.
Old Jun 18, 2017 | 02:12 PM
mtwoolford's Avatar
mtwoolford
thermostats can stick or not open at all; I'd replace the Tstat...and no I don't want to start another thermostat / thermodynamics debate, but I'd put in a 160 or 180 degree Tstat.
To Water Pump
