1986 Reading Codes
Old Jul 5, 2017 | 08:52 PM
86couper's Avatar
86couper
Default 1986 Reading Codes
1986 Service Engine light is on. I am trying to determine the best way to read the codes. I have no device at this time for reading OBD I codes. What is a good economical way to retrieve the codes. I see that Advanced Auto has a OBD I reader very reasonable. I do have an ACTON 9570 OBD II reader and have seen on Amazon where they make an adaptor cable to go from OBDI plug to OBD II reader but am skeptical about this option. When you have an OBD I reader where do you actually see the codes listed? On the device or the dash? Any help would be greatly appreciated. Thanks.
Old Jul 5, 2017 | 09:10 PM
Patsgarage's Avatar
Patsgarage
Looking at Actron's website your scanner does not support OBD I, even with the cable. You can use the paperclip method and count the flashes of the CEL to get the code, or buy a cheap OBD I scanner that will display the codes and some live data, but to erase them you still have to disconnect the battery.
Old Jul 5, 2017 | 09:42 PM
xrav22's Avatar
xrav22
I have an Actron Scanner or odbII and I could not get it to work with the cable. I just used the paperclip and a notepad for writing codes.
Old Jul 5, 2017 | 10:08 PM
Cjunkie's Avatar
Cjunkie
Dude just get a paper clip, count the SES light blinks, google the code.
Old Jul 5, 2017 | 10:18 PM
Not4spd's Avatar
Not4spd
Here's the video I did but you can make a paper clip into a U shape and ground the pins on the OBD I port. Then you count the SES flashes on the dash. If you can't find the codes let me know i have the book in the video and can tell you what the code is.
Old Jul 6, 2017 | 11:28 AM
86couper's Avatar
86couper
Thank you everyone. Paper clip worked. Placed paper clip in far right top two positions. Obtained codes 33 and 36. Now the fun begins.
Old Jul 6, 2017 | 06:27 PM
Cjunkie's Avatar
Cjunkie
33-MAF
36-MAF Burn off relay
Old Jul 7, 2017 | 02:54 AM
Cliff Harris's Avatar
Cliff Harris
Follow this link for a list of error codes and what they mean -- all years:
https://www.corvetteforum.com/forums...post1576116036
To 1986 Reading Codes
