Gauge Fix
Old Jul 9, 2017 | 11:08 AM
BillDurant's Avatar
BillDurant
Default Gauge Fix
I have to fix the Gage Cluster on my 1989 Vette
any one have any advice or have any feedback on this guy?
Old Jul 9, 2017 | 11:13 AM
slow-vette's Avatar
slow-vette
He is Awesome. I highly recommend him. He does great work. He has done my cluster and my brother in laws. Prices are more then fair and he will bend over backwards to help. Great customer service.
Old Jul 9, 2017 | 11:14 AM
BillDurant's Avatar
BillDurant
Default Gague Fix
Ok great thanks
Old Jul 9, 2017 | 11:23 AM
BillDurant's Avatar
BillDurant
Default Gague Fix
Originally Posted by BillDurant
Ok great thanks
Did you have to take the dash top off ?
Old Jul 9, 2017 | 01:46 PM
383vett's Avatar
383vett
I recently had a problem with my 84; could barely read the gauges in the daytime. Called Bryan at Batee. He sent me a photocell kit which fixed the problem for less than $30. The video shows the dash top being removed. I just pushed the the top up to remove the cluster. Did not have to take it off.
Old Jul 9, 2017 | 01:55 PM
hcbph's Avatar
hcbph
Bryan does great work, someone I recommend highly.
Old Jul 9, 2017 | 11:25 PM
86couper's Avatar
86couper
https://www.youtube.com/watch?v=P0BmiFFeT58
I had him do my 1986 over a year ago and it works great. Turned it around in a week.
Old Jul 9, 2017 | 11:28 PM
confab's Avatar
confab
He's the best.. I totally trust him.
Fixed my video game dash up sweet with his parts and he was very helpful.
A+++++
Old Jul 9, 2017 | 11:29 PM
confab's Avatar
confab
No.
Old Jul 10, 2017 | 11:41 AM
Weck86's Avatar
Weck86
No, but it makes access and removal of dash cluster easier. Dash top comes off easily. Most difficult for dash top are the screws in the defrost area. I've had mine off three or four times.
Old Oct 7, 2017 | 09:49 AM
BillDurant's Avatar
BillDurant
what did you pay to get the cluster re done and is it bright easy to read?
thanks
Old Oct 7, 2017 | 02:48 PM
Hot Rod Roy's Avatar
Hot Rod Roy
It's not necessary to completely remove the dash. Just remove the screws along the front (closest to you) so you can lift the dash a little bit. That helps a bunch! The clips on the connectors are the biggest challenge. To remove the headlight ****, slide a small screwdriver along the shaft in the slot to release the internal spring clip.
To Gauge Fix
