Sounds like it's time for a new windshield. You could stop by one of those windshield chip fix it places. Usually they have one at the attended automated car wash places or they set up tents in shopping center parking lots. They might be able to inject epoxy into it and make it harder to see.
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Did it start out as a chip? If it was due to a thrown stone etc then your insurance should pay to have the windshield replaced. Call your agent and discuss.
My NCM insurance paid for that exact problem a couple of years ago. I even got to pick the shop that did the replacement.
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Do your research and find a shop that has experience with C4's. If you don't you'll probably be sorry.
That's the question you need to ask. Friend called a windshield installer and they said,"Sure we've replaced lots of Corvette windshields." When the guy actually saw it, he didn't have a clue where to even start on a C4. I've heard other windshield guys that have actually done C4's say they are the "most difficult windshield there is" to replace! You need somebody with past experience on C4 windshields, not just any old Corvette! BIG difference!
Safelite did mine. But, I had to call around to find a shop where someone had experience with a C4. They did, but I had to drive to their location so they'd be sure if there was any issues, they'd have the ppl to deal w/ it.
There were a couple minor issues, as it turns out:
the "trim" pieces they provided were not a good fit, and I ended up reusing the originals, after I cleaned the old glue from them
I had previously ordered the rubber from Corvette Rubber (like OEM and much nicer than theirs) and they installed it and discounted the price by the cost of their rubber.
Beautiful glass! No leaks. FYI, The ZR-1s came with a reflective laminate sandwiched between layers of glass. It was suppose to reduce AC load due to heat. The issue is/was delamination, beginning at the periphery and eventually working toward the middle. It's easy to see the "delam" around the edges, but it is subtle closer toward the middle and not immediately noticed.
Wow! Soon as the new glass was installed, you could instantly see how bad the old WS had deteriorated! (I had the standard (tinted) windshield installed, rather than replacing the ZR-1 WS...and I LOVE the clarity!)
Cost? Been a while, but IIRC it was ~$275 installed w/ my rubber and trim pieces.
I did Safelite also, staretd small but all the bumps and twists made it all the way from side to side, geico hooked me up, only have $100 deductabile, safelite, my trim and rubber ....been 2 months and its actually quieter...lol..targa was a bitch but its all settled now
To the OP, take this advice and dt86's very seriously if you have your windshield replaced. And I think you should as your crack is too large for repair and will only spread. All newer car windshields are "glued" in place and have no trim pieces. So one car's windshield is the same as another to an installer. Not so the C4. I believe the C4 WS actually has "some" structural rigidity to the car and must be installed correctly or will crack again if stressed, i.e. you hit a large pot hole. Also the trim pieces, to my knowledge, are no longer available, thus the originals MUST be reused and are a huge pita to get off without bending. Most installers don't want to take the time. Hence shop replacement on experience and knowledge rather than price or as dt86 suggests, you'll be sorry.
JM Autoglass came by a tried a fix. The result wasn't good. So they didn't charge me. He said at least now the crack won't spread. He told me to find a deal on a windshield and he'll install it on a weekend for $60.
Obviously he has never done it. You'll need a new A Pillar weather strip for a start as well as windshield.
Take to Safelite and plan on leaving car all day.
