They couldnt do it
anyway atleast we can drive the car but the crank seal needs to be dealt with.
esp after only having the car for 3 months! however Ive been lucky all these yrs not getting lemons so maybe it was time.
Let’s see, I pulled the following items when I was down under:
The full cat back exhaust
The driver’s side cat
Passenger side lower support brace
Oil filter and adapter
The flywheel dust cover (covers the rear pan bolts)
The oil pan
Various electrical connectors
On the front of the motor:
Drained radiator
Removed radiator hoses (big and little ones)
Remove the MAF air sensor (rubber tubes) from intake
Throttle body
Fan belt
Water pump
Lower pulley
Hub
Pulled and moved Alternator and AC unit out of the way
Pulled Opti
Removed timing chain cover
Now you can clean up all the parts and remove the gaskets from the parts and the motor surfaces. (This was a lot of fun.)
Now put all the parts back on with new seals and gaskets. Don't forget the burp the cooling system when you add new coolant.
The oil pan
Drained radiator
Throttle body
Fan belt
Water pump
Lower pulley
Hub
Pulled Opti
the part that gets me is they were already at the part just couldn't get it out!
The most critical tool to have is the Kent-Moore tool to r&r the hub. With a conventional puller, it's a puzzle to figure out that can take newbies 1-2 hours. With the KM tool, it literally takes 5 minutes to pull the hub.
On the timing cover is an indentation near each seal and using a small screwdriver and hammer, each seal is easily removed. Putting a *small* amount of RTV around each new seal, allows them to be simply seated in place. Note that the water pump seal requires a tool to properly install it over the water pump drive.
Also....Over time the seal wears a groove in the hub. When that happens, it'll still leak even with a new seal. You can buy a new hub or install a sleeve (available from FelPro) over the old one.
I've also done plenty of oil pans. That's a 5-6 hour job. Jacking the engine 1-2 inches helps with reinstallation.
that's some good info and am sure everyone here would like to know more in-depth details
