New plug wire install.
Old Aug 3, 2017 | 08:07 AM
bill herried's Avatar
bill herried
Default New plug wire install.
I will soon be changing my plug wires. Are there any suggestions or tricks that might be helpful? I have new AC Delco wires, die electric grease, a good plug wire puller and new combs, in case the old ones break. I know to do them one at a time.
Old Aug 3, 2017 | 08:22 AM
81c3's Avatar
81c3
Early or late C4? L98 or LT1?
Old Aug 3, 2017 | 08:31 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Only suggestion, is a old timer trick, oh I must be old to mention this trick.
Take spark plug to any parts store, I used Pep-Boys and bought 12 inch long hose, you can cut to what you need for your use, and get hose with diameter that will fit the spark plug nice and tight.
I experience right side of the engine the spark plug under the compressor on my L-98 just about see it, no less reach in with new plug.
Since you don't mention what year of car, I hope this helps you out.
Old Aug 3, 2017 | 08:34 AM
bill herried
Actually I have replaced the plugs a couple of times. It is the wires that I am replacing now. The hose trick is good though. Thank you.
Old Aug 3, 2017 | 08:36 AM
bill herried
87 l98
WVZR-1's Avatar
WVZR-1
But you still haven't mentioned what year/engine combination - your post #5 must have topped mine by maybe a second or so. It ain't "top secret" any longer!
Old Aug 3, 2017 | 08:37 AM
bill herried
The years is 87 L98
Old Aug 3, 2017 | 08:39 AM
81c3's Avatar
81c3
L98 is a walk in the park... If you have a few extensions and a wobbly 5/8" plug socket, thats pretty much all you need... If you did the plugs, those were more involved than the wires... you should have no problem
EDIT** Behind the #7 & #8 cylinders can be a little bit of a PIA.... You will need to be patient if you plan on running the wires the same way the factory did...
Old Aug 3, 2017 | 11:32 AM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Pfffpt, #2 on '87 is a big PITA without a tidbit.
Don't try to remove from above the engine, instead get the wobblies as mentioned and come in through the wheel well side panel. Much easier to get at #2. Putting the new plug in is still not the bright side of your day.
Old Aug 3, 2017 | 11:36 AM
bill herried
Thanks but it is the spark plug wires I am replacing.
Old Aug 3, 2017 | 01:17 PM
81c3's Avatar
81c3
Hmm, what changed between 86 & 87? Mine was easy as pie.... all stock.
Old Aug 3, 2017 | 01:29 PM
Joe C's Avatar
Joe C
just a note - don't get carried away with the di-electric grease. a little dab on a Q-tip, and a quick swirl around the inside of the boot is all you need. you only need it at the plug end, and keep it away from the center contact of the plug wire itself.
Old Aug 3, 2017 | 02:51 PM
hcbph's Avatar
hcbph
Here's a trick that works for some. If you have to maintain crossing wires etc, it's easy to mess up. Assuming you aren't pulling them off all at one, tie a cord to the end of a wire. Now pull the wire off the plug or distributor and pull it to the other end, dragging the cord behind. You can then attach your new plug wire to the cord and pull it carefully back. If you had any crossovers etc that needed to be maintained, you're good as gold.
Old Aug 3, 2017 | 03:22 PM
bill herried
Thank you for the input. I will certainly give that a try.
Old Aug 4, 2017 | 02:55 AM
Cliff Harris's Avatar
Cliff Harris
Lay out all the spark plug wires and start with the longest ones. Match to the wires on the engine and install one at a time. The wire for #6 has a weird spark plug boot to get around the oil dipstick tube.
Old Aug 4, 2017 | 04:05 AM
Joe C's Avatar
Joe C
here's a good link to another thread on wire lengths. https://www.corvetteforum.com/forums...e-lengths.html -- this will apply to OE style replacements. OP, if using a factory routing remember #1, #2, and #3 route behind the distributor (in the cavity just below the distributor cap) DESPITE what the FSM says -
To New plug wire install.
