ecm computer
Old Aug 6, 2017 | 07:57 PM
mouser's Avatar
mouser
1st Gear
Default ecm computer
can i put a1987 ecm computer in a 1985 corvette. reason is motor was rebuilt to 383 stroker now i can not set old computer to this motor.
Old Aug 8, 2017 | 07:07 AM
blackozvet's Avatar
blackozvet
ok, Ill deliver the bad news - no. The 85 uses the '870 ecm and the 86 and later uses the '165 ecm, the looms are slightly different so it wont work.
If you need a tune then it doesnt matter which one you use anyway.
there are still some people around (not many) who can burn an 85 chip.
or consider a Dynamic efi - http://www.dynamicefi.com/EBL_Flash.php
Old Aug 8, 2017 | 10:23 PM
gerardvg's Avatar
gerardvg
Hi
You only need to calibrate the MAF table increase it by 10% for a 383 engine, I use Tunerpro and a moates ostrich emulator to do it myself.
It is a steep leaning curve to use tunerpro, always make do a backup !!
I still run the 85 ECM with my 383.
The other option is to get your MAF calibrated for the 383 engine and larger injectors.
Old Aug 9, 2017 | 03:59 AM
Cliff Harris's Avatar
Cliff Harris
Putting a 1227165 ('86 - '89) ECM in an '85 is a pretty common modification. There are several web sites that will tell you how to do it. It's mostly moving some wires to different positions in the ECM connectors.
To ecm computer
