amp removal
Old Oct 4, 2002 | 05:37 AM
jtfrog's Avatar
jtfrog
Default amp removal
I need to replace the door amps in my 86 vette. can this be done with out removing the door panel and also without removing the box
Old Oct 4, 2002 | 11:01 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: amp removal (jtfrog)
Newbie, huh? Pssssssssst. I'd peep out the car audio portal for this one. :cheers:
[Modified by onedef92, 10:01 AM 10/4/2002]
Old Oct 4, 2002 | 01:40 PM
hotwilzz's Avatar
hotwilzz
did this on my 89, and not only will the door panel have to come off but it is quite a challenge after that as well. getting the box out of the door is a real PITA. once you remove all the screws that are holding the box, it will still be glued to the inside of the door frame, just push on it and it will come off, then bring it out the largest opening in the door frame. I found it harder to get it back in than out, maybe it was just me.
good luck
Old Oct 4, 2002 | 01:48 PM
Kale's Avatar
Kale
Its a big hassle. If you're going to do this, might as well go full aftermarket stereo.
:D
To amp removal
