92 door panel
Old Aug 22, 2017 | 10:28 PM
mjfox's Avatar
mjfox
Default 92 door panel
HI guys
my door panel is loose on top near the glass
how is attached
not sure
thanks for help
mike
Old Aug 23, 2017 | 08:03 AM
Kevova's Avatar
Kevova
The top of door panel "hooks" over door frame. There are several screws that hold panel on. The molded plastic that loops over top of door frame is probably broken .
Old Aug 23, 2017 | 10:33 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
So... How are your rubber window "sweeps?"
I ask as if your door is coming off (as it will) for you to re hang it, you are half of the way done on doing a new set of window sweeps.
I did mine about 2 months ago. Not a bad job and once your panel is off, you are only looking at an additional 45 minutes.
Old Aug 30, 2017 | 04:18 PM
net_coma's Avatar
net_coma
I think I now know the answer to my question from almost 3 years ago when I bought my 94. After I had it awhile I noticed two screws in the drivers door panel, upper right corner in the coped area at the dash. Now I know what the previous owner did to it. I have to remove the panel to replace window sweep, look at window regulator. After I find a replacement door panel, hard to live with it and have others think I did that to the car.
To 92 door panel
