Wrap headlights
Old Aug 26, 2017 | 05:43 PM
StateCollegeC4's Avatar
StateCollegeC4
Default Wrap headlights
i like leaving the headlights up all the time in my white 1989 coupe but I am thinking about having them wrapped to give it a unique slightly modern look. The color I am thinking is metallic charcoal by 3M. I might also do the two little side gills in the same color for balance. It's pretty neutral color with a hint of warmth that I think coordinates with the saddle interior.
any thoughts??
Old Aug 28, 2017 | 07:24 PM
TA's Avatar
TA
I think the charcoal would be a nice contrast to the white. Just out of curiosity, why keep the lights up all the time?
Old Aug 28, 2017 | 08:23 PM
StateCollegeC4
Thanks for the reply. I guess I just like them up. It's just a different look.
Old Aug 28, 2017 | 08:36 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
It would look good, but do not buy those black headlights. I made that mistake and they were the biggest turd a Vette owner can buy.
Old Aug 28, 2017 | 09:17 PM
FAUEE's Avatar
FAUEE
You're going to wrap the buckets in a different color?
It'd certainly be different, I don't know that I would think it would look good, but if you like it, go for it and post pictures of how it looks.
Did you just disconnect the wiring that rotates them to keep them up, or are the motors busted? To me, headlights up like that means busted motors.
Old Aug 28, 2017 | 11:20 PM
BrandensBeast's Avatar
BrandensBeast
I painted mine black on the old 84 that I had, interesting but I would never paint them if they were in good shape, obviously wrapping is different though!
Old Aug 29, 2017 | 01:47 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Are you prepared to answer questions about what's wrong with your headlights? Kind of like putting "directional" wheels on backwards, 'cuz you "like 'em that way". It's your car!
Old Aug 29, 2017 | 07:39 AM
Renfield's Avatar
Renfield
Default Over it
As autumn approaches, I will manually rotate mine up. They'll stay up until the vernal equinox. Both are unplugged, though the passenger side still worked last time I tried.
I am done throwing money at one of the most ridiculous engineering fails ever.
Saving up for a fixed aftermarket solution.
Curious to see your wrap.
Old Aug 29, 2017 | 10:41 AM
FAUEE's Avatar
FAUEE
I might be in the minority, but I don't consider the lights an engineering fail. Do they require upkeep? Sure. But they're all 20+ years old now. At 20+ years old, I think it's fair to have to replace some plastic parts.
Old Aug 29, 2017 | 11:28 AM
Renfield's Avatar
Renfield
As it turns out, you are. The "lucky" 40 percent. This design has a 60 percent fail rate. It does not compare favorably to the flip up headlights on other cars like say a 22+ year old Miata.
I recall seeing a lot of winking C4's back in the day too. GM finally fixed it in the C6.
My Eckler reman died one month out of warranty. I've been as entertained with C4 pop ups as I care to be. Maybe when everything else is fixed I'll have another look. Don't expect that day to arrive.
Old Aug 29, 2017 | 02:14 PM
StateCollegeC4
The only people that ask that Q are corvette junkies.
Old Aug 29, 2017 | 04:13 PM
Patsgarage's Avatar
Patsgarage
You might have better luck using Plasti-dip. The buckets have some tight corners that might be difficult to wrap unless you are a pro. Since you have to disassemble everything anyway, I would just paint them. I do like the color you picked, that will go with the white nicely.
Old Aug 29, 2017 | 05:51 PM
ovrebo1's Avatar
ovrebo1
If I saw mismatch colored headlight buckets that were up in the daytime I would just think you had a problem with them or the motors, replaced them and haven't gotten around to making them work correctly.
To Wrap headlights
