A/C advice
Old Aug 26, 2017 | 09:21 PM
gman35's Avatar
gman35
Default A/C advice
My brother in law has a 1994 C4. He was telling me that his A/C was'nt working. He also stated that he was told that it is controlled by the computer. I am not familiar with the 1994 c4 but I am pretty good with my 1987 C4. My a/c works fine and I do the work on it myself. I don't want to give him incorrect info on his car... butt does anyone know if the computer can be the problem. thanks, gary
Old Aug 27, 2017 | 09:49 AM
jpipx's Avatar
jpipx
I'm sure there's some control there depending on the climate control system type. Always best to check the basics first... put a manifold on it and check the pressures, compressor, etc... When I had an issue with the A/C in my 95 C4 it was low freon pressure and I just need to top it off and monitor. The low pressure valve is notoriously weak and can leak (which it did in my case).
Old Aug 27, 2017 | 10:52 PM
gman35's Avatar
gman35
Default thanks
Thanks for the reply.. I suspect it is low freon and the low pressure switch has it locked out.. I have all the tools to work on it.. I told him to bring it by. Thanks again, gary
To A/C advice
