Cooling system vacuming
Old Aug 28, 2017 | 08:40 AM
fake's Avatar
fake
Default Cooling system vacuming
On a C4 if you can not get to the knock sensors for a cooling change can you vacuum the system? Also where would you attach to drain the block?I have a Mityvac vacuum cylinder (gallon give or take ) for liquid storage which came with the unit. Has any one tried this method?:
Old Aug 28, 2017 | 12:26 PM
JimLentz's Avatar
JimLentz
I don't see how that would work. Some have been known to drain from radiator only and fill with distilled water a few times until it comes out clear, then fill with coolant/distilled water. Be sure to start between cycles and run heater to flush out heater core. I think something like 5 cycles or so.
Old Aug 28, 2017 | 01:34 PM
fake's Avatar
fake
Default cooler than hell
Thats what i did on my Passat took for ever but its cleaner than a fresh diaper
Old Aug 29, 2017 | 07:54 AM
Renfield's Avatar
Renfield
When I pulled my sensors, a flood of coolant was released from each. I'm with Jim. Don't see how you'll do a decent job without pulling the sensors.
It's not just about draining coolant, either. Knock sensors fail and/or seize in the block over time. Tons of threads on this forum where, especially the passenger side, gets stuck. Then you're in for some pain, because the wrench point is soft metal that breaks free.
As long as they're not seized, really a pretty easy task. What is keeping you from just pulling the sensors?
Old Oct 6, 2017 | 10:00 AM
fake's Avatar
fake
Default sucked it out
I used my vacumn to suck out the anti freeze and got very little on the opti. It is a clear canister with diffrent clear hoses to evacuate liquids. It is two feet tall bought it at NAPA. Worked great
Old Oct 6, 2017 | 11:40 AM
DGXR's Avatar
DGXR
I'm glad the vacuum worked for you but the block may still have sediment. I agree with the others, you really should pull the knock sensors for a proper flush. It's not very hard.
Old Oct 6, 2017 | 12:16 PM
Renfield's Avatar
Renfield
Okay. Again, what is stopping you from simply pulling the knock sensors and getting zero on the optispark?
Skip this step at your own peril.
Old Oct 6, 2017 | 02:40 PM
Hot Rod Roy's Avatar
Hot Rod Roy
The Knock Sensors are located in the block drain holes. You can't get the sediment out of the block without removing the KS's. Some years have only one KS, but there's a plug on the other side.
Old Oct 6, 2017 | 11:08 PM
Komiller118's Avatar
Komiller118
They are easy to remove................... just do it
Old Oct 21, 2017 | 06:42 PM
fake's Avatar
fake
Default done
Suck out the cooling system and didnt get a drop on the floor. Now i will run distilled water until clean.
Old Oct 23, 2017 | 04:38 PM
belairbrian's Avatar
belairbrian
I'll just say this.
I pulled my knock sensors yesterday on my 92. I have the entire cooling system apart. Since the water pump was already off, the amount of coolant in the block was a little lower than it would be.
When I was done I measured it and there was one US gallon that came out. Think about that. Even after pulling all the hoses and the water pump there was still a gallon in the block.
Why on earth would you not pull the knocks? Was this a case of changing the coolant without lifting the car?
It took all of 15 minutes and 4 tools to drain the block. Ratchet universal adapter and a 2 sockets.
Old Oct 23, 2017 | 04:55 PM
DGXR's Avatar
DGXR
Originally Posted by belairbrian
I'll just say this.
I agree 100%.
The vacuum method used by the OP is pretty effective and likely removed most of the coolant from the block. So it's not really necessary to pull the knock sensors to do a coolant change. The issue here is the potential for leaving behind sediment deposits, which could cause hot spots and promote corrosion in the cooling jackets (both caused by poor/incomplete coolant circulation). Sediment deposits in the cooling jackets will only come out when the knock sensors are pulled and the jackets are physically cleaned out (pressure washer, hose nozzle, length of wire, etc). It's not guaranteed that there is sediment, but with the age of our cars, it's not worth taking the risk. So I fully agree, if you're going to maintain the cooling system, spend an extra 20 minutes and clean out the block properly.
To Cooling system vacuming
