Low coolant light
Old Sep 4, 2017 | 01:43 AM
C4Boston's Avatar
C4Boston
Default Low coolant light
My Low coolant light comes on just as thermostat opens and goes out after a few minutes. This just started recently, plenty of coolant in expansion tank.
Old Sep 4, 2017 | 04:42 AM
Cliff Harris's Avatar
Cliff Harris
What year is the car? Makes a HUGE difference...
Old Sep 4, 2017 | 09:16 AM
hcbph's Avatar
hcbph
Regardless of the year, here's some basic info that might help. If you use Prestone or comparable antifreeze it fluoresces under black light. You can use a black light to look for tracks around the engine. If you use a cooling pressure testing system, pressurize the cooling system to about 15 psi and look and listen for a leak.
In my case, I found the U shaped hose that goes between the block and tpi behind the water pump had a crack in it. I replaced the hose to fix the leak but wasn't able to get all the air out of the system. My final solution that worked: with the engine cold, I took off the radiator cap and put a coolant jug with the bottom cut out in the radiator neck and taped it in place. When the engine comes up to temp the coolant drops in the radiator at which time I topped off the radiator and capped it. At that time it now worked as it should and have been able to check fluid level via the overflow jug as you should be able to do.
Old Sep 4, 2017 | 09:20 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the sensor can go bad and cause a leak in the sensor and corrode the electrical connector
Old Sep 7, 2017 | 09:45 AM
C4Boston's Avatar
C4Boston
Originally Posted by cliff harris
what year is the car? Makes a huge difference...
1986
Old Sep 7, 2017 | 10:32 AM
c4cruiser's Avatar
c4cruiser
The Low Coolant sensor is located just below the pressure cap. A single green wire attaches to the sensor. It could be that the syste mis just low enough on coolant that when the 'stat opens, coolant is drawn from the radiator and causes the sensor to operate.
With the engine cold, remove the pressure cap and start the engine. Let it run until the thermostat opens. You should see the coolant level drop some. Run the engine at about 1100-1200 RPM and add coolant until the level come up to the bottom of the filler neck. Replace the cap and shut the engine off.
The coolant level in the expansion tank is actually pretty low when cold. There are two marks; the COLD mark is about an inch from the bottom and the HOT mark is about 2" above that. Use a Sharpie to mark the lines so you can easily see them. The tank is easy to remove so it may be a good idea to remove the tank and clean it out.
Old Sep 7, 2017 | 02:17 PM
C4Boston's Avatar
C4Boston
Thanks, I will do it this weekend.
To Low coolant light
