Possible bad Knock Sensor
I have a C4 88' all stock with 98k miles. I was getting the dreaded SES lite, it would come on for a few minutes and then go out. It seem to come on just as the engine bucked or missed (Slightly)... a few times and then would smooth out. I had it looked at by a local trusted mechanic and the didn't get any codes. I had a fuel injector system flush done thinking it was carboned up and I had not had one done in a few years. They did see evidence of carbon build up. But a few days later the SES can on again and this time stayed on, AND the engine was running rough, like it was only hitting on 7 cyl. A code check showed 42 & 43.
From what I've read, code 43 could be a bad knock sensor. My question, would a bad knock sensor cause the engine to run rough?
