after taking off stomp pedal on floor I get a little bit of shaking in front end .When car was delivered chains was across the lower a frames .They don't look bent or anything ..tires are good aliment seems ok no pulling when letting go of wheel .no vibration just a shake ..Any thoughts
How fast are you going? Have you already gained speed, or is it more like an engine miss/vibration? Thoughts are possibly engine mounts, trans mount even...
BTW, its never a good idea for the aluminum, A arms to be used as anchor points. They can bend!
