C4 Engine pics
My 86 C4 convertible has been apart too long, and now I'm having trouble remembering how to get everything together on the power steering pump, AC, and accessories brackets. Yes I have the shop manual, but I'd like some close up engine pics that show which bolts go where on the accessories. Looking around the internet, I didn't see anything that was sufficient. Sorry for the dumb post. Anyone have any or care to take any pics for me? Silly thing is that I've had this car apart several times before over the last 25 years and never had trouble getting it back together before...must be getting old.
I usually am pretty careful about labeling and bagging everything and taking pictures, but the last time it came apart the idea was that it was just for a weekend...and things got worse from there...
Thanks,
Mark
I have an '85 and I doubt the accessory mountings are up to NCRS standards, but they're all attached and functioning.
Kind of hard to get pics of the front of the motor, but here's a couple to get you started.
Might work better if you tell me what you want to start with and I can tell what bolts or brackets I see/feel where.
Thanks,
Mark
Thanks,
Mark
on the AC bracket, there are six fasteners. two (3/8-16) nuts attach the bracket to the water pump studs on the RH side of the pump. there is a funny looking flange bolt at the 6 o'clock position. this bolt has a flat cut into the flange, and a torx recess in the head. not sure of the size, but i'm guessing it's a 3/8-16 bolt, and attaches via, the front of the bracket, into the block. there are 2 other bolts that come in from the rear, they are M10-1.5 bolts - one is 110mm long, and mounts to the far RH side of the AC bracket. this bolt also holds, under the head, a small support bracket . the other end of the bracket mounts to a stud-bolt on the exhaust manifold, and is secured with a 3/8-16 nut. the other bolt is 105mm long, comes in from the rear (you may have to remove the valve cover to install that bolt). those 3 (long) bolts secure the compressor to the AC bracket.
on the power steering bracket, there are 3 fasteners that secure the bracket to the block. one of those fasteners is a stud and does double duty holding the smog pump bracket. that fastener is at the upper inboard side of the bracket. at the 6 o'clock position is a 3/8-16 x 1.375 bolt that secures to the block. at the far, upper, LH side of the bracket is M8-1.25x20mm bolt that comes in from the rear side of the bracket and secures the pump, and three (3) M8-1.25x20 bolts secure the pump from the front.
hope this helps...
