Power steering fluid issues
Old Sep 23, 2017 | 07:59 PM
Teyoloky's Avatar
Teyoloky
Cruising
Default Power steering fluid issues
Hey Corvette Forum
just a question here... I am having some issues with my power steering fluid.
The other week I took my 85 out to a track day and it really ran well. No issues with overheating or anything. Only one issue, about 2 laps in, my car was billowing smoke. I didn't even notice until I was flagged to get off the track, it was all flying behind me.
After opening the hood I found out that my power steering fluid had shot out of the corners of the cap and leaked onto some hot parts, which burned the fluid off and made the smoke.
Ive replaced the power steering fluid and cleaned the engine bay up.
This was a pretty "bendy" course that had me constantly making sharp turns. What made the fluid leak out like this? Do you think it was over-filled before?
Let me know what you guys think!
Old Sep 23, 2017 | 09:58 PM
Patsgarage's Avatar
Patsgarage
I would agree that it was probably overfilled and the cap did not seal all that well. If you refilled it to the correct level just keep an eye on it for a few days, everything should be fine.
Old Sep 23, 2017 | 10:10 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
i bought a set of felpro gasket sheets and cut new gaskets out of cork. easy.
Old Sep 24, 2017 | 08:14 AM
C409's Avatar
C409
..... You might consider a power steering oil cooler .....
Old Sep 26, 2017 | 10:44 PM
Benny42's Avatar
Benny42
This ^ . I drag race my car. I have replaced the rack in my car, then the PS pump, then the high pressure hose. I added a Z51 PS cooler and so far, no new issues.
Old Sep 27, 2017 | 11:21 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
C4 PS is known to be problematic on the track. The earlier systems are notorious for fading and overheating.
If you plan to continue with "fun" driving, I suggest an investment in a race prepared PS unit.
Or you can waste time and money trying to modify the OEM pump.
Black flags are a waste of fun time and money.
Old Sep 28, 2017 | 10:19 AM
c4cruiser's Avatar
c4cruiser
Does sound like there was too much fluid. When I ran my '87 on track days, I removed fluid from the reservoir so that the stick on the cap showed the fluid level at the "ADD" point.
I did add a PS cooler and that helped a lot with fluid temps. IIRC, it was a Perma-Cool unit but I don't think they make a specific PS cooler any longer. It was a small two row unit and I mounted it in front of the front crossmember. I also used Red Line Synthetic PS Fluid and that fluid completely stopped all of the whining from the original pump when it got hot. I recall doing some track days where the air temp was 100 degrees and never had an issue.
Old Mar 27, 2018 | 02:23 PM
cooljunk's Avatar
cooljunk
Default power steering leak
Looking in my gasket collection for a gasket for the power steering cap, found a Cev. V8 distributor gasket fits that "backwards" cap perfectly.
To Power steering fluid issues
