Should I purchase 93?
Old Sep 25, 2017 | 11:31 PM
Rexy$$'s Avatar
Rexy$$
5th Gear
Default Should I purchase 93?
Hi all,
Old Sep 25, 2017 | 11:42 PM
FAUEE's Avatar
FAUEE
IMO, there are no bad years of C4. They all can be reliable, they all can handle well, and they all wee fast in their day. None of them are fast by today's standards, none of them will set record times at road courses today, and none of them are as reliable as they were new.
Bottom line is, it's all in how well the car has been treated. Even beyond that, at some point, even the best cared for car ages and needs parts replaced due to age/mileage wear. If you want a car to look at, buy the one with the shiny paintjob. If you want the car to DRIVE, buy the one with the maintenance and parts replacements.
Don't know enough about the options of the particular car, where you're located, r anything like that to give an accurate price, so I would recommend against paying anything more than $20k, or anything less than $2k.
All jokes aside, I don't think you will be satisfied by an LT1 car if the '84 was too slow for you. Your wallet may not be deep enough to satisfy your desire for speed.
Old Sep 26, 2017 | 12:05 AM
Windir's Avatar
Windir
I purchased my 93 a few months ago and haven't had any issues (so far). I paid 14k and the car only had 18,500 miles. I agree with FAUEE, if your looking for speed, the LT1 is okay but certainly not fast and the targa top is a pain to remove. Overall it's still a beautiful car and fun to drive, but sinking lots of cash into it for increased horsepower would quickly equal what they're worth.
Old Sep 26, 2017 | 12:09 AM
81c3's Avatar
81c3
Honestly, you're looking at a near 100,000 mile Chevrolet. You should expect to have things go wrong and they will inevitably. On top of that, its a sports car and sports cars are built to drive.... sometimes hard. don't blame an 84 Vette with a bunch of miles on it and 30 year old technology for not being as fast as a new sedan of present day.... Thats just the reality of things.
If you are patient, you can find the right car... If not, its a crap shoot. Look for maintenance records with any car you buy. Look for an enthusiast selling a car, shy away from dealers....
Good Luck!
Old Sep 26, 2017 | 12:10 AM
Rexy$$'s Avatar
Rexy$$
5th Gear
Well I wish I had money to get one with such low mileage! I did not mean it as though I was looking for the fastest car I could find. 300 hp is plenty for me. Just looking for a nice vette for my boring drive through the mountain roads to work. Would it help if I post some pics of the ins and outs of the car? thanks so much.
Old Sep 26, 2017 | 06:41 AM
hcbph's Avatar
hcbph
Originally Posted by Rexy$$
Only issues I saw was a slightly wobbly steering wheel, leaky valve cover, brights wont work. It really seems like it has been taken care of. Matt
Lights are obviously electrical issue in some form. The steering could be cheap or expensive, it all depends. If you're not up to it, may be short $$ to have a competent shop go through the car pre-purchase if you think this is the one. Steering issue might be steering column, alignment, brakes, rack, tires or a number of other possibilities. Could be cheap or could be expensive, all depends. Worst case, keep looking as there are many C4's out there and with fall coming many sell rather than store them for the winter.
Good luck however it turns out.
Old Sep 26, 2017 | 09:21 AM
Cool Runnings's Avatar
Cool Runnings
I don't know, I've got a 92 auto with a 3:07 axle and the car is pretty quick, even by today's standards.
Old Sep 26, 2017 | 09:55 AM
fredk's Avatar
fredk
Same colour and year as mine. The problem with the high beams sounds like mine, it was in the steering column. I would go for it, I love mine which has a lot of money under the hood.
Old Sep 26, 2017 | 10:09 AM
biggiefl's Avatar
biggiefl
I was impressed with the LT1 as far as HP went. I still had to go for the ZR1 however. For $5k, looks good. LT1's are pretty bulletproof and read about their cooling system which is one reason they last.
Old Sep 26, 2017 | 10:12 AM
JimLentz's Avatar
JimLentz
Matt, see if anyone here that knows C4s is local to you and can help you evaluate the 1993 Corvette.
Old Sep 26, 2017 | 11:06 AM
belairbrian's Avatar
belairbrian
High beams are likely a 30 minute fix. The switch gets out of adjustment and won't "click In"
If you mean the steering wheel can be moved around while sitting still, it's either the bolts holding the tilt mechanism, or the mechanism itself. Caused by people using the steering wheel to get in and out.
Valve cover leak is an easy fix.
If those are all that is wrong I don't see any real issues
92 and 93 have the in-vented opti-spark. I figure if mine goes bad, I'll replace and add the venting kit.
Old Sep 26, 2017 | 11:21 AM
RtStuf's Avatar
RtStuf
Don't forget to budget for getting the rear wheels corrected - they are presently on backwards - if tires are unidirectional, may have to be remounted to the wheels when corrected.
Old Sep 26, 2017 | 11:50 AM
aklim's Avatar
aklim
Before we go there, why don't you go get a corvette shop you trust to do a Pre Delivery Inspection where they check everything out? Drop trans pan, check fluids, compression, history codes and what the repairs cost to bring it up to spec? Too many idiots get starry eyed and buy the car, any car, only to find it is a POS after a detailed inspection.
Old Sep 26, 2017 | 06:23 PM
DGXR's Avatar
DGXR
I agree 100%. Have someone check it out. Know what the car is and what it's not, before you buy. Definitely ask for maintenance records, that is a must for me. Remember it's a toy, not your main transportation. Take your time.
Also, define "wobbly."
The later C4s have better performance than the earlier models, primarily due to the LT1 engine. Everything got better, more refined and more reliable over the 13-year run, but that is true of any generation of any car... as is true to avoid the first year or two of any new car (or next generation/full redesign). The early C4s are good cars but the later models are better.
Old Sep 26, 2017 | 07:13 PM
1993C4LT1's Avatar
1993C4LT1
How much? Sorry if I missed it.
Old Sep 26, 2017 | 07:56 PM
cv67's Avatar
cv67
St. Jude Donor '05
If it shakes at speed it could be the rack and pinion..or an out of balance tire.
Old Sep 26, 2017 | 08:01 PM
aklim's Avatar
aklim
Basically it moves up and down (not too too much) and it shakes while driving a little faster but when I stiffen it up with my hands it kinda stops.
Mention it to the mechanic and ask him to check out the shocks and bushings.
To Should I purchase 93?
Old Sep 26, 2017 | 08:48 PM
Rexy$$'s Avatar
Rexy$$
5th Gear
Probably the first one if it doesn’t really shake when I hold it down with both hands?
Old Sep 26, 2017 | 09:17 PM
1993C4LT1's Avatar
1993C4LT1
93s rock. I have one. If you like it, and believe the trade is good. Go for it. No need to over think stuff.
Old Sep 26, 2017 | 09:39 PM
Rexy$$'s Avatar
Rexy$$
5th Gear
Thats what I’m thinking.. how long have you had yours?
