Wiring expert needed badly!
Eckler's shows an Early and Late configuration for '85, but no details. Corvette Central, Mid America, and Corvette America do not show E/L, and show '85-'87 as the same relay (no details).
WVZR-1, I can't find any details on the GM10038311 either. Do you know?
Larry, when you get your new relay, can you please post a picture of the electrical diagram that hopefully will be printed on the case? If your new relay has contacts at A, B, C, & E, the mystery will continue!
There's many here with '85 cars so confirmation of theirs should be easy. There's Joe C, IHBD, Randy M and others that all have original cars. The car needs checked and NOT the FSM!!!
Here's a 10038311 pinned as I would have expected. Pay no attention to the offering.
https://www.ebay.com/itm/C4-Corvette...NZsqGj&vxp=mtr
The relay Lentz mentions is what I'd expect in an '84 "only" according to all the early GM SPO catalogs I've seen. I don't usually look at most html links but did just now to see what he might have had in mind.
I think that's the answer! The '84 relay is A, B, C, D! So Larry's car is EARLY, and his connector (and the diagram) matches the '84 relay!!!
(My '84 doesn't have the original relay. My relay was cooked when I got my car, so I rewired it for an 80 A relay. No more relay problems!)
The OP mentioned ordering a relay to match his connector so his decision is made it seems.
Maybe the OP will mention a VIN when he posts back!! That would be interesting - maybe!!
For anyone just cruising through, this is how the '86 & 87 that also uses the GM SPO 10038311 relay shows being wired in a schematic.
Whalepirot has mentioned in the past that early '85 cooling fan wasn't controlled by ECM but a switch like the '84. I've no idea. Notice that in post #2 schematic there is a "switch" and that diagram is for a single fan.
A, B, C, E would be like the eBay link I supplied. RED is either @ D(4th) or E(5th) position of the connector. One cavity of the connector shell should be empty, 4th or 5th. You shouldn't have to remove anything to confirm. Mention the last 8 digits of your VIN.
OR MAYBE the key is the connector shell color with GREEN being early and if it were BLACK then maybe it's A, B, C, E. '86 and '87 I'd expect a BLACK connector shell for sure.
Does your car have AUX fan also or just single?
My car has just the one cooling fan, I think. Now I'll have to check.
What are the last six numbers of your VIN?
(I'm betting that most '85's have A, B, C, & E pins. GM may have been planning to use the same relay in the '84 & '85's, but started seeing problems with the '84 relays after the '85's got into production. My pure speculation!)
'85 certainly an interesting build.
If there is a switch also then it would seem very easy to use a switch with the lower "turn on" temps.
Randy M - if you've looked and confirmed only 1 fan is there also a switch in the RH cylinder head?
It certainly would be interesting for '85 owners who believe their car to be original post to this thread. Maybe the V08 option changed the wiring scheme and relay applications.
Did you look to see if yours actually has a switch in the RH cylinder head? Does your car have the V08 option?
What is the last 5 digits of your VIN and production date from the drivers door label.
*** You posted the RH cylinder head snapshot in while I was typing!! Switch is present and I'd expect a DK GREEN wire. The FSM has an image that shows the switch both with and W/O V08 so regardless of relay configuration I'd think it's there.
Larry, if turn on your ignition, then ground the green wire at the temp switch in your right head (between spark plugs 6 & 8), your fan should run. Squeeze the fat sides of the connector to remove it.
It's obvious that Larry's car previously had an A, B, C, D relay in it, otherwise the connector wouldn't have been overheated!
