Radiator Flush
Old Sep 29, 2017 | 10:07 AM
marines's Avatar
marines
Default Radiator Flush
Good Morning All:
I recently had the radiator of my 1996 C 4 flushed and new fluids added. I read somewhere that GM engines should have some sort of additive to prevent leakage. I checked my reservoir last night and it was low. I had the work done about three months ago and it may be low as the engine probably had to "burp". My question: What additive should be included, if any?
Thanks for all your help in the past.
Old Sep 29, 2017 | 10:35 AM
mickey5's Avatar
mickey5
I believe Chevy sells a sealer over the counter. I don't know if its the same as added at the factory. Ask the counter man or someone may chime in here.
Old Sep 29, 2017 | 10:48 AM
Whaleman's Avatar
Whaleman
I am also looking forward to experts answers. I flushed complete and did not add the sealer pellets. Dan
Old Sep 29, 2017 | 10:54 AM
c4cruiser's Avatar
c4cruiser
GM used to install "sealer pellets" as part of a cooling system service done at dealerships or they sold them over the parts counter. They came packaged in a blister pack of 6 pellets.
Some years ago, GM issued a TSB telling service departments to stop using the pellets as they could cause clogging up of the tubes in radiators. Don't know if they are still available from GM parts departments. but personally, I would not use them. If there is any leakage from the cooling system, the leak should be fixed properly.
Old Sep 29, 2017 | 12:40 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I have flushed the radiators for my Z28, 92, 95, 04 and The Ghost. Never added snake oil to it. Ensure you NEVER mix the green coolant with the orange coolant and you will be fine.
50/50 mix is good for all states unless you live in SoCal. I do 70/30 here.
Old Oct 1, 2017 | 10:38 AM
Warren Seale's Avatar
Warren Seale
The pellets that GM sold/recommended at that time were just the well known Barrs Stop Leak tablets that you could buy at any auto supply shop.
To Radiator Flush
