Ethanol Free?
Old Oct 2, 2017 | 04:48 PM
sedgwick24's Avatar
sedgwick24
Default Ethanol Free?
So this is gonna sound off the wall. I am seeing ethanol free gas show up near me more and more. I have started using it in my yard equipment to try and stop the corrosion and the varnish. Question I had is if this would be a good thing to use in my car? Its the same price as the premium so switching over would not be a huge issue financially. Just waned to know if it would be worth trying to use it in the car or just stick with the premium.
Old Oct 2, 2017 | 05:34 PM
crowz's Avatar
crowz
All of the ethanol free stuff around here is 87 octane and I would rather have premium since my vette pings with 87 octane. That said if I was going to park the car for a long time then yes the ethanol free would be a good choice. I use stabile (spelling?) fuel treatment in mine to get around the ethanol issue as much as I can on mine since it sits most of the time.
Old Oct 2, 2017 | 05:55 PM
Whaleman's Avatar
Whaleman
I am lucky as a local Amoco has 91 octane ethanol free gas. It is more money. I use it. Dan
Old Oct 2, 2017 | 07:46 PM
hcbph's Avatar
hcbph
We have non-alcohol gas around here, I don't remember if it's 91 or 93 octane but it's like 50 cents a gallon more than the highest octane gasohol gas.
I use it when I put mine into winter storage along with Seafoam. Does an excellent job helping protect the fuel system from gunk.
Old Oct 2, 2017 | 10:39 PM
FAUEE's Avatar
FAUEE
Some stations around here only carry ethanol free premium. It's not cheap.
For me, I run whatever premium I find. If you let the car sit a lot for weeks it might not be a bad idea to get ethanol free. Either that or some of that ethanol additive stuff and mix it in with your last tank of fuel before putting it up for the year.
Old Oct 2, 2017 | 10:59 PM
aklim's Avatar
aklim
My problem with ethanol free, assuming that it is not some slimy and/or careless SOB doing it and that it is honestly ethanol free is that if it is not used often, we might be getting more stale gas. Many cars are NOT using 93 and some of the cars that do mandate 93 also have cheap users using 87 because "It is cheaper and I used it with no problems." not to mention people using 89. I kinda wonder how often the fuel tanks are refreshed. If I were that worried about it, I'd dump Marine Stabil in the fuel and be done. Otherwise, I think I would be better off with fresh 93 even if it had ethanol as opposed to stale ethanol free 93.
Old Oct 2, 2017 | 11:27 PM
FAUEE's Avatar
FAUEE
Actually, the % of cars that require premium is at its highest level ever. Supposedly sales of premium gas are very, very strong. Many times all the 89 you get at a station is a mix of 87 and 93 anyways.
I'm glad my daily driver truck takes regular. I had been looking at a few options, but decided on one that definitely takes regular (V8 Colorado). My best friend didn't and bought a Silverado SS, which requires premium and knocks if you put it under load on regular pretty badly.
Old Oct 3, 2017 | 08:41 AM
Randy M's Avatar
Randy M
I have always used the ethanol free gas in everything I own, vehicles and small engines. I always use Stabil and have never had a problem with anything. I just changed the fuel injectors on my 85 Corvette because I had the intake apart for new gaskets. The injectors were the originals, I am the original owner of my 85. To my knowledge the injectors were working just fine with 90,000 miles on them. I replaced them because of age and mileage. I will only use the tainted fuel when the ethanol free is absolutely no longer available.
Old Oct 3, 2017 | 08:58 AM
bac22's Avatar
bac22
When driving/filling on a regular basis, gas with ethanol is fine, it's when parking for a while (like over winter) it can become a problem which is why one should use a stabilizer.
I had posted this article in another thread, good article that explains what happens to ethanol gas and pretty much relates to any gasoline engine.
http://www.boatingmag.com/gear/boati...ilizers#page-8
Old Oct 3, 2017 | 09:34 AM
aklim's Avatar
aklim
I suspect that your injectors were "just fine" because ethanol did not screw up the coils since the Multecs, if that is what you had, are fuel cooled. Whether the pintles were clogged up and how much, we will never know since you didn't test them, hence the "just fine" report. I suspect that it you did, you will find that there is varnish built up and impending the flow. Because the ECM compensation is present, you don't know whether is is there or not. Even pre ethanol days, the jets would get clogged so what more with injectors that have even smaller holes?
Old Oct 3, 2017 | 10:50 AM
GRIS's Avatar
GRIS
"Carry Nation gas" has always been available here in the Ind'n Nations, 87,89, & 91 octane. I run 67 in my pickup and all small engines and 89 in my 'vettes with no ping or problem. A lot of stations only have two grades in the tanks and three grades on the pump, so you get the same gas for 89 & 91, just at a different price.
I think non-alcoholic gas is a must for small engines.
Old Oct 3, 2017 | 11:31 AM
vader86's Avatar
vader86
I always use E0 whenever possible in older cars and all lawn equipment, the corvette gets 93 octane E0 and I get over 1mpg better just from that, plus I let it sit a week or two at a time depending on season.
For newer cars since E10 was introduced, it doesn't really matter for them as theyre set up to handle the corn liquor in the fuel system but if youre still letting it sit then its not a bad idea.
Old Oct 3, 2017 | 12:01 PM
aklim's Avatar
aklim
No ping or problems as perceived by you or the sensor?
The ECM, as I am told, can retard timing by up to 20 degrees when it perceives knock. That makes me think that if all it takes is UP TO 19 degrees, you won't hear knocking. Once it needs to retard more than 20 degrees and it cannot, you will hear the knock. So when you don't hear it, does it mean it isn't occurring or is the ECM compensating?
Old Oct 3, 2017 | 03:14 PM
DGXR's Avatar
DGXR
"Stick with the premium" ... sounds like the ethanol free (E0) gas available is regular? If this is the case, you should stick with the premium when driving the car regularly. And I agree with the other post about filling the tank with the E0 regular if you plan to store the car longer than a few months, adding a stabilizer to the tank.
I wish we could get E0 in my area.
I've run regular in my car a couple times and you can definitely hear the engine ping *before* the computer pulls timing. It's not severe and it lasts only a fraction of a second, but you can definitely hear it. And of course you can feel a power drop at the very instant timing is pulled. I noticed this many times when testing a few tanks of regular and mid-grade... it did not ping all the time, but happened more often when engine temps got into the 215-225F range. It was an easy decision to run premium full-time in this car. It still pings with premium, but it is very rare and only under specific conditions.
Old Oct 3, 2017 | 07:38 PM
sedgwick24's Avatar
sedgwick24
I think I mis-spoke about the grade. Most of the stations in my area have 88 octane ethanol free but there are a couple that have 91 that I would most definitely use. When I said "stick with the premium" in my mind I was separating the premium with ethanol with the ethanol free 91.
My thing is that its driven at most about 20 miles a week as I take the train to work to avoid traffic and gas costs (my work will reimburse me for the train but not gas). Would using the 91 E0 be a good option seeing as I don't drive it too far every day so I can try to avoid the corrosion from the fuel sitting for longer periods than most dailys?
Old Oct 3, 2017 | 07:41 PM
sedgwick24's Avatar
sedgwick24
You have a point about the gas sitting if its not used too frequently. Think it would be a good idea to find out how often the tanks are emptied and refilled? I know normal stations in my area are refilling about once a week but would the E0 be able to sit for a little longer since the alcohol isn't in it?
Old Oct 3, 2017 | 07:58 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Several stations in our area have started carrying 93 octane ethanol free. Same price for it as for E10 premium at other stations. Perhaps it's a win-win.
To Ethanol Free?
Old Oct 3, 2017 | 08:45 PM
aklim's Avatar
aklim
How cold does Utah get that you store it or have to worry? Also I doubt it is much of a corrosion issue, at least where you are. Now if you are a boat, I'd be more worried. If your injectors are Multecs, I'd be more worried about the ethanol killing them and dump them straight away so you can do whatever you want.
My injectors have varnish built up which is why I send them out every 3 years so I do a bunch of stuff like cleaning the TB and other routine stuff during the down time. I have Bosch 3 so ethanol isn't an issue. I do drive it in the winter when I can so I could care less if ethanol gas is available or not.
Old Oct 4, 2017 | 08:27 AM
Atomic6's Avatar
Atomic6
I was always getting 93 'no ethanol' but they went down to 90 octane about 6 months ago and I could hear the 'ping' in my LS1 Trans Am. I went back to the 93 octane with ethanol. It was nice while it lasted. I did fill up a Phillips 66 in Townsend , TN last week that had the 93 'no ethanol' and it cost $3.19 a gallon which was similar to other 'premiums'.
Old Oct 4, 2017 | 08:58 AM
Randy M's Avatar
Randy M
Yes, a lot longer. Ethanol is the week link in storing gasoline and other things, but I won't get into that.
