does anyone on Long Island have a late C4 with poly bushing suspension?
I have a 96 coupe, with the base suspension. 70k miles. I'd like to overhaul my suspension soon, and replace the wear/tear items (springs, shocks, bushings, etc.). I'd also like to preserve as much ride quality as possible (our LI roads are riddled with potholes and bumps). My research has led me to believe that no one produces rubber suspension bushings anymore, which means polyurethane is probably the next "softest" option. Before I go down this path, I would like to ride in a fellow CF member's late C4 who has poly bushings, but stock-style Bilstein suspension. Let me know if anyone can help out here, before winter comes...
Not in Long Island..although FL basically is a New York. I have a 94' Coupe with the FE1 Suspension, 125k miles. I have new Bilsteins, and Polyeurthane bushings throughout (except batwing). Rides great, I honestly cannot tell a difference in the "pliability" or compliance between the stock rubber or poly. However, you do notice the more positive feel. Not much help since you can't ride in it, but thought you may appreciate the feedback since it sounds like our C4's will be similar once you do the changes.
You really don't have much of a choice if the stock rubber is deteriorated. Banksi and Del-Alum is the way to go, but nothing wrong with Poly at all. When I was changing out all the bushings the only ones that REALLY needed it were the sway bar bushings and the rear trailing arm (dog bone) bushings. The rest were actually in very good shape.
I had replaced the bushes with prothane ones, I was quite disappointed with the ride afterwards. The suspension feels 30% stiffer, even though I used plenty of the special lube the ride is harsher and feels bouncy.
The trailing arm bushes secured with 8 bolts really don't want to flex like the old rubber bushes, you cannot get rubber bushes anymore.
So am looking to go to Banski trailing arms with spherical ends,
that wont restrict suspension movement and restore the ride.
That is my experience.....
Randy M (10-04-2017)
The reality is GM never offered the bushings as a service part. You had to buy the arm. With the soft suspension you have, maybe some noise. If it's a major worry move newer or older. It's unlikely the c4 will get rubber replacement bushings.
I live in the lower hudson valley, and did a full suspension refresh on my 95 coupe last winter. New Bilstein shocks, new poly bushings all around, u-joints and bearings. In my opinion the ride is great... I like the way the car hugs the road now. Very positive traction around all curves. My 95 vert is all factory with the original rubber bushings. I like the ride in both but prefer the coupe now for those long, winding roads.
-Does it have the base suspension?
-Did you notice that the ride quality is any stiffer or softer now with the new poly bushings, Bilsteins, etc... ? I would suspect stiffer, now that you converted to poly bushings....but I would also think softer, after getting rid of 20+ year old/hard rubber bushings. Not sure which overcomes the other
Received 3,043 Likes
St. Jude Donor '05
Anything is better than worn out rubber, these rode like buckboards when new anwyay
Great info. On your coupe:
I have 94, base suspension, poly all the way around with AC Delco shocks. I don't feel the ride is any more harsh than the old rubber bushings - but the C4 isn't a "smooth" ride to begin with. I don't regret the poly one bit, car is all around more planted. Haven't heard any squeaks from the poly yet.
The problem in general with poly bushings is that they are not compliant in torsion. for many locations (e.g. camber rods or A-arms), this is no problem since they only rotate around the bushing's intended axis (the bolt). But for the dog bones (trailing arms), it is a problem since they must not only rotate around their bolt axes but must also twist when the car rolls. This tends to add a rising rate to the wheel rate in roll, which makes for non-linear handling - not good.
Back in the day, people used to go with poly in both ends of all four trailing arms in Fox and SN95 Mustangs. That was a worst-case scenario, and made for lots of scary handling cars! I don't know how much it would add to a C4 - I'm sure it's less because at least the trailing arms are parallel to each other in plan form. But I still would recommend against poly in the dog bones. It would be worth just buying complete dog bones instead. The Banski trailing arms are a great option, too.
my 96 coupe had the base suspension AND a delaminating rear spring
replaced the rear spring with a 480 inch pound spring from VB&P...which is the rough equivalent of the heaviest Z51 spring offered...replaced all the rear suspension bushings with polyurethane, including the bat wing to frame bushings. I'm very happy with the ride and handling and that's over some pretty rough local roads...my only suggestion is use way more lube than the kits supply and lube EVERYTHING generously.
and yes, in the next evolution, heim joints, but for bang for the buck, poly's a huge improvement.
