clunk from left rear
Old Oct 10, 2017 | 08:16 AM
sharkface's Avatar
sharkface
Default clunk from left rear
1985 C4. When accelerating fast from a dead stop, there is a slight clunk. It sounds like it's the driver's side rear wheel area. When starting out slow, it is not heard. Any ideas?
Sharkface
Old Oct 10, 2017 | 08:20 AM
81c3's Avatar
81c3
Check shock for tightness. Same for the brake caliper, trailing arms and then possibly the 1/2 shaft U-joints
Old Oct 10, 2017 | 11:13 AM
sharkface's Avatar
sharkface
Default Clunk C4
Thank you so much for the reply. The sound really is a nuisance on a car that is otherwise original, and tight.
Old Oct 12, 2017 | 09:12 AM
C409's Avatar
C409
..... Lug nuts , stub axle shaft nut , C-beam bolts , U-joints , etc. .....
Old Oct 12, 2017 | 11:05 AM
sharkface's Avatar
sharkface
Default Left Rear Clunk
Thank you for the response. I am bringing the car next week to a friend's garage for a free check up. I am lately thinking it must be the U joints on the driver's side half shaft. (I am quoted from another garage 5.5 hrs to change one side) A good reason to buy a couple of wheel chocks, a large vice, and make it a winter project.
By watching on Youtube, the job looks difficult, but not impossible to do in your home garage.
Old Oct 13, 2017 | 06:29 AM
bac22's Avatar
bac22
I had a similar problem, thought it was u-joints, but turned out to be wheel bearings.
Old Oct 16, 2017 | 02:56 PM
DGXR's Avatar
DGXR
Also check all the suspension bushings. My car had a knock similar to yours, it was the sway bar end link bushings. Easy fix, hope yours is too
Old Oct 18, 2017 | 06:59 PM
BadUmp's Avatar
BadUmp
as odd as it may sound, check the spare tire carrier - - - I'd been hearing an odd noise from mine and just this past I happened to be changing a rear light bulb and realized that the carrier was loose. The donut tire must have shifted a bit and that allowed a bit of slop in the whole set up . . .
Old Oct 18, 2017 | 09:24 PM
383vett's Avatar
383vett
Check the exhaust too. Possibly pipes or mufflers hitting the body during acceleration. I've pulled axleshafts and changed ujoints many times in my garage. Not that hard to do. It takes a little time.
To clunk from left rear
