Nightmare
Old Oct 22, 2017 | 06:49 PM
Gatorlaw's Avatar
Gatorlaw
Default Nightmare
Installed a new power steering pump, hoses and serpentine belt. All I can say is what a pain in the ... Disconnect battery. Remove alternator. Begin wrestling match with bolts on smog pump. Get that out and start pulling power steering pump. One bolt on bottom buried inside the pullies. Had to use an open end wrench to back that one out. Then getting the old pulley off was a pita. Omg. I don’t want to have to do that again.
Old Oct 22, 2017 | 07:09 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Yep, I agree with you on that one! I drilled a hole in my PS pulley at that bolt location so I can get at the bolt with a socket wrench. That made re-assembly easier, too!
