84 Headlight question
Old Oct 29, 2017 | 09:51 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default 84 Headlight question
my F-I-L's 84 when the headlights close the drivers side motor keeps running, but the light is in the down/closed position, that motor is a newly replaced for another issue. I know it is different than my 90.
Ideas on what to try or replace?
Old Oct 29, 2017 | 10:04 PM
Patsgarage's Avatar
Patsgarage
If you can manually rotate the **** on top of the motor and open the light, the "pellets" are no good. If you can't then look for a problem with the linkage between the motor and light housing.
Old Oct 29, 2017 | 10:15 PM
-=Jeff=-'s Avatar
-=Jeff=-
motor goes up fine.. goes down fine.. when it hit the stop, the motor keeps running
I think it might be the isolation relay.. worth the $25 to try
Old Oct 29, 2017 | 10:28 PM
WVZR-1's Avatar
WVZR-1
I'd think the internal switching of the motor - is the "newly" replaced motor new, reman or used? If it's new or reman with warranty I'd be inclined to contact the vendor.
Old Oct 29, 2017 | 10:53 PM
-=Jeff=-'s Avatar
-=Jeff=-
both the right and the newer left worked without issue when i installed it last summer. he has always had left side issues prior to this one, which is why I lean towards the relay that senses when the motors should stop. When I am not as limited with my crutches, I will check it more in depth
Old Oct 31, 2017 | 02:44 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Sorry, this is bad info.
1. The manual control ***** on the '84 motors is on the bottom of the motor, not the top. The '88-'96 motors have the ***** on the top.
2. There are no "pellets" in the '84 motors, only the '88-'96 have "pellets".
The only way an '84 motor could continue to run is if the gears are stripped. You say this is a "new" motor. Somehow I doubt that.
Old Oct 31, 2017 | 09:49 AM
-=Jeff=-'s Avatar
-=Jeff=-
Motor assembly was probably remanufactured.. It worked 100% correct when I installed it last year. I currently am unable to work on it to find the issue. As stated, there was a different issue, which led to the replacement of the motor.
When I am able I will troubleshoot and find the cause.
I already knew it was not the pellets, those are in my 90 motors.
To 84 Headlight question
