96 LT1 collectors edition. I replaced front engine seals, rebuilt opti spark, water pump,plugs, wires. Car barely idles now with no acceleration. Tried new temp sensor with pig tail no difference. Re checked wires firing order all good. I do not have alternater hooked up do to 3wire plug damaged. New one on way. Any ideas greatly appreciated. Car ran perfectly fine before this. Thanks
More over, what does that mean? Are you running the engine on battery power alone? Is the battery fully charged? Why did you tare the car down to begin with? Help us to help you....
Crank seal was leaking. Has 90,000 miles all original. Opti spark had crack across face so installed new rebuilt one,water pump,plugs, wires. Battery power only right now, just wanted to start it and make sure it would run.
Tried to run scan. No codes. Engine idles little while about 500rpm then dies. Will not rev up or run long enough to bring a code. Old opti did work. Take apart again tomorrow put old opti spark back in see what happens
If you want, turn the idle adjustment screw in till you get a stable idle and scan. Don't care about the codes yet. See what you can get for IAC count with engine at stable operating temp and everything but the motor off. Report back
One question. I do not have alternator hooked up due to broken 3wire plug. Could this be the cause of my problem ? Running on battery power just to see if engine ran after repairs. New alternator plug on way.
Battery fully charged. Very rough low idle will not rev up. Could the rebuilt opti spark be a problem ?
It could be. What was the problem with the opti that you needed it replaced? I would wait for the alternator though before I do anything else just to be 100% sure
When replacing crank seal noticed crack in face of opti spark and burned spot. 90000miles so figured replace it while pump off. Don't know if alternator had to be hooked up to complete some circuit
If I'm understanding correctly, the car was running fine except for an oil leak.
Now it barely runs.
So the most likely causes are a bad part, or something got put together wrong or damaged.
I'd look at every connector that was touched. Lots of stuff gets disconnected getting to the opti. Could be a connector, say the TPS or IAC connector is loose. A wire could have been broken.
And yes you could have crossed wires. I was absolutely certain my wires were right, except they weren't.
You mentioned a new rebuilt opti. What was the source?
Sounds like 1 of 2 things. weak or improperly timed spark or that the IAC valve is not working properly. The last LT1 I rebuild would idle at 450rpm and was very hard to bring up because of a bad IAC valve AND a bad opti.
