Polishing Kit????
Old Oct 9, 2002 | 01:01 AM
Reddog's Avatar
Reddog
Default Polishing Kit????
Id like to start polishing my own stuff, can anyone make any recomendations? :cheers:
Old Oct 9, 2002 | 01:19 AM
1bad85's Avatar
1bad85
From: livin life one hold my beer moment at a time Houst Tx
Default Re: Polishing Kit???? (Reddog)
Get you a big ole can of elbow grease.
Old Oct 9, 2002 | 02:21 AM
GlockLT4's Avatar
GlockLT4
Default Re: Polishing Kit???? (1bad85)
hehe :D
do you mean the paint or metal under the hood and such?? if metal, get an air compressor and polishing tools. If paint... uh, go to the paint store ;)
Old Oct 9, 2002 | 09:39 AM
vettmech's Avatar
vettmech
Default Re: Polishing Kit???? (GlockLT4)
I have a buffer on my bench grinder. I use all those fancy jewler's compounds. There are a lot of supplies out there........ go to the Eastwood company web site....... I don't know if they show it on line but the stuff is in the paper catalog........ all kinds of buffs and compounds. I like to do a lot of my work in advance of tearing stuff down.......... I filed my runners and plenum before I pulled it apart so I had less work to do ......... after filing you can do all your sanding too......... the engine will look like crap for a while but next spring it'll be fine........ good time to fix that intake coolant leak :lol: The valve covers are magnesium on mine and don't saty nice if they get water on them ........ but Mothers cleans them right back....... BUT there was a LOT of filing, scraping and sanding on those suckers to get them the way you see them in my sig.......... there are all sorts of things on an L-98 to polish and once you get the bug ya can't quit ........ I'm deatailing my upper control arms now in preparation of urethane bushings :seeya
Old Oct 10, 2002 | 01:26 AM
GDP's Avatar
GDP
http://www.gmtips.com/3rd-degree/dox/tips/tips.htm
You'll find a section for Buffing Aluminum, good info. I just found out about this site ten minutes ago and I've already posted it twice now. :crazy:
To Polishing Kit????
