Premium Gas?
Old Oct 11, 2002 | 05:23 AM
  #41
GRX's Avatar
GRX
Default Re: Premium Gas? (jdog0411)
Premium! :smash:
Old Oct 11, 2002 | 04:36 PM
  #42
Feenix566's Avatar
Feenix566
I don't think my baby's ever had anything less than sepreme, and I don't plan on ever changing that.
Until I do the engine swap whenever the L98 dies, and start running ethanol.
Old Oct 11, 2002 | 05:19 PM
  #43
Alchemist's Avatar
Alchemist
NC Events Coordinator
The vettes get premium....always!!! :D
Old Oct 11, 2002 | 06:05 PM
  #44
Vette Girl's Avatar
Vette Girl
Cruise-In IV Veteran
Here in WV we have Regular (low grade), Premium (middle grade) and Supreme (high grade). I only use supreme! I'm thinking your meaning premium is supreme right?! :cheers:
[Modified by Vette Girl, 10:06 PM 10/11/2002]
Old Oct 11, 2002 | 06:16 PM
  #45
Nassau Blue C5's Avatar
Nassau Blue C5
Always Premium!
Old Oct 11, 2002 | 08:05 PM
  #46
KyleBst264's Avatar
KyleBst264
Default Re: Premium Gas? (bradvette)
I use Sunoco 94 octane :D
Same here. Always, nothing less.
Old Oct 11, 2002 | 08:27 PM
  #47
minnasotajim's Avatar
minnasotajim
Premium only !!!
Old Oct 12, 2002 | 10:31 PM
  #48
R23HTC's Avatar
R23HTC
Default Re: Premium Gas? (minnasotajim)
Premium only. The ONLY time I made an exceptionnn was when I was on reserve and the gas station was out. I put in $5.00 unlead plus and drove to the next closest station and filled up with premium. :yesnod:
Old Oct 13, 2002 | 11:50 AM
  #49
rcolling's Avatar
rcolling
Default Re: Premium Gas? (R94 LT 1)
Running Premium out here in Ca is like running the mid grade a couple of years ago. It is only 91. :U
Old Oct 13, 2002 | 02:43 PM
  #50
Rubyred's Avatar
Rubyred
[QUOTE]My question is, with the price of gas like it is,/QUOTE]
Let's do the math. 6,000 a year (I put on the car) divided by 20 m.p.g (mostly highway at 26 MPG) times 20 cents a gal. (difference between regular and premium) equals $60 a year. I stick with premium.
Old Oct 13, 2002 | 07:49 PM
  #51
your drinking buddy's Avatar
your drinking buddy
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: Premium Gas? (CowboyNVette)
Always use 93
Old Oct 23, 2002 | 10:41 PM
  #52
Reno67's Avatar
Reno67
Default Re: Premium Gas? (vettes rule)
Premium 93 octane from Amoco/BP. Original owner used only this...... so I figured I would too.
later
Old Oct 23, 2002 | 10:53 PM
  #53
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
I used regular one time and lets just say the vette and I were not talking. (I was sleeping on the "couch") So later that week i went back to premium and been doing it ever since.
[Modified by flyinace2000, 9:55 PM 10/23/2002]
Old Oct 23, 2002 | 11:21 PM
  #54
no_radio's Avatar
no_radio
Default Re: Premium Gas? (stillthere)
i use premium in the car, truck, boat, lawn mower, every gas engine i have. the money you save on the cheap gas you spend on tune ups and other repairs. the premium fuel has a cleaner burn and leaves less residue behing. over time that residud builds up in your engine causeing all sorts of problems. if you can afford the good gas use it.
well, as an employee of a MAJOR oil company I can say that you are not completely correct. If the engine doesn't NEED the octane (because of high compression ratios or high operating temps) the premium gas can actually hurt the power output. The only thing octane does is reduce detonation, because it is less "volatile" than lower octane fuel. For lawn mowers, low performance engines, etc this can result in lower power output. Nowadays all grades of gasolines from the major oil companies (Shell, Chevron/Texaco, Exxon/Mobil) have the same cleanliness additives and will not trash your engine/fuel system. If your vehicle doesn't need the high octane stuff save your money and buy a quality low octane fuel.
If you use cheap grocery store gas it doesn't matter what octane level you buy, you are trashing your fuel system. Period.
Jeff
