Strange problems with my 1984 crossfire
Ok so I'm having some problems that I think might be the ECM. TPS stays at .507 volts even when throttle is moved. Have coad 21. When I jump a&b on the OBD1 fans don't kick on but fan works as it should kicks on at temp when running. Also when a&b are jumped the IACs pulse in and out. IACS extend all the way out when it's running but when you open the throttle they stay extended out. I'm thinking with all this that the ECM is bad. What do you guys think
I would test tps with a ohm meter. Does engine still have original round connector type coolant and air temperature sensors, if so change to new style. Check sensor ground circuit, no ground will cause ecm to read sensor source voltage all the time. Too early to condemn ECM.
If you ohm A to B at at sensor will reading should change as level is moved. C should be ground. Old style connector had multiple reliability problems. Are you using FSM?
yes did just that and no change in TPS with movement of throttle or TPS adjustment. No manual new to Crossfire engines but have owned and diagnosed over 40 TPI engines just never seen one do all these strange things at one time I don't understand what would cause the fan to not turn on when you jump the A and B terminals on the OBD1 plug and turn the key on but the fans work like they should when the car is running and why wood the IAC sensors pulse in and out all power and grounds to everything is good I have seen TPS is go bad but usually they still change voltage when you move them around it blows my mind that it just stays at the 507 volts no matter where you move it or how
Zen Vet Master Level VII
Your ECM is pretty bullet proof- really.
For your cross-fire you need to have really good/functioning TPS, coolant sensor, IAC.
Kevova is correct on upgrading to the dual wire sensors. even if it not your specific problem, you will be glad you did.
Yep, need to dial in your TPS. That sounds like the first point of failure.
I have not disconnected it to see if anything changes I'll give that a try do I want test where the black and blue wire would plug into or the black and gray wire would plug into on the TPS itself
The fans are only controlled by the switch on the head. It isn't supposed to come on when you jump the terminals on the port. That is if I remember correctly and that mine works normal.
That's normal. The only thing that activates the fan in the '84 is the CTS in the RH head (between cyl 6 & 8), and the pressure switch in the a/c compressor. Period. FSM pg. 8A-149.
The only way you would know that is if you've got the IAC's removed from the throttle bodies. If the engine is running, the ECM would see way too much air, so would extend the IAC pintles in an attempt to decrease the air flow thru the IAC circuits! FSM pg. 6C14-2.
IAC's extend all the way out when it's running but when you open the throttle they stay extended out.
First step would be to check the voltage output of the tps when the throttle opening is changed. Pretty basic. When a lamp doesn't work, you check the bulb first, not the fuse panel.
Am I correct in assuming that you have run the engine with the IAC's removed from the throttle bodies? If so, there is a special procedure you need to follow before the IAC's can be re-installed, otherwise damage will result to the IAC's, since the pintles have become extended. This is covered in the FSM pg. 6C14-9.
You do have the '84 FSM, don't you?
yes it runs but it idles at about 1300 RPMs then drops down to 9 and Hans back and forth from 6 to 9 has hesitation on take off
okay I unplugged and tested it at the TPS itself and yes I got a change when I move the arm but with it plugged up it just stays at at 5 .07 no matter what I do adjusted or move the arm
Key on engine off.
Back probe the wire in the center of the tps connector with your voltmeter. I'm pretty sure its either blue or purple, but I don't have the proper schematic. Back probe means you leave the connector connected, and using a needle or something similar, carefully insert it into the back of the connector, or pierce a tiny hole in the wire and seal it with silicone later. Try to back probe and not pierce the wire. Pierce as a last resort.
What voltage do you have at closed throttle and open throttle ?
Also, are you using a scan tool to tell you what the ecm is reading for tps voltage ? Or how are you doing that exactly.
Key on engine off.
Key on engine off. Everything connected as normal.
Using a needle or whatever, back probe the black wire. What is the voltage reading ?
