Bosch EV14
Old Nov 24, 2017 | 02:50 PM
RWDsmoke's Avatar
RWDsmoke
Default Bosch EV14
I have not heard much about Bosch EV14's on this forum so after I bought a set and ran them for about a year I am going to share my experience with them. They are new, not "rebuilt" and come with full documentation including flow rates at different pulse widths, and voltage offsets.
I know most people like their Bosch 3's, but I've had two sets and while they worked great while accelerating and cruising, not so good at low speed. I even sent one set in to have them checked and the report said they were matched within 1%. After trying hundreds of different combinations of timing and fueling I could not get my car to run as smooth as it should under 1200 RPM'S. Blm's and wide band both indicated fuel was correct. Driving in stop and go traffic on a hot day was very annoying, to the point I was not driving my car as much as I normally would. Finally bought new Bosch EV14's. Day and night difference. I love my car again, My idle and light throttle operation is so much smoother.
I've never had much luck with rebuilt anything, including fuel injectors. This is a much newer design than the Bosch 3 and they are compatible with ethanol. These are not drop in, the smallest i've seen is 35#. They cost more than rebuilt of course but in my opinion, well worth the money. I only wish I had the money back I spent on other things trying to solve my idle problem.
Old Nov 25, 2017 | 08:28 AM
jetskibruce's Avatar
jetskibruce
I am curious, is your car running a stock ecu and program, or has it been tuned?
Old Nov 26, 2017 | 12:36 AM
alankb's Avatar
alankb
following
Old Nov 26, 2017 | 01:13 PM
RWDsmoke's Avatar
RWDsmoke
There is nothing stock on my car. I even call it a junk yard dog. The motor is a ZZ430 clone with an Edelbrock pro-flo intake. I'm now using an EBL Flash ECM.
This is a year round daily driver. Winter in San Antonio lasts 3 or 4 days sometimes. I've had this car almost 15 years and plan on keeping it in the family for many more. I will pay more for parts that last longer.
I started this thread because after all my research looking for injectors, I liked what I read about the EV14's but found nothing from people that are using them. I called DeatschWerks and they were able to give me all the information I needed. Tuning is so much easier if you have all of the correct information about your injectors to start with.
Old Nov 27, 2017 | 12:55 AM
scotth48's Avatar
scotth48
Last spring I sent my bosch 3's and 4's in to be checked. The 3's flow rate was around .248 and the 4's were around .298. So I put the 3's back in my '93 lt1 to get better mileage. Not sure what the flow rate was for the multecs but heard they were in the same range as the 3's. One question I do have is what is the replacement injector for the zr1 lt5 engine?
Old Nov 27, 2017 | 06:04 PM
Cjunkie's Avatar
Cjunkie
Old Ford 5.0 19lb Injector that we threw out new by the dozens lol!
Old Dec 2, 2017 | 09:47 PM
odxr's Avatar
odxr
I have some pink Bosch 3’s in my 87 that came out of a Volvo.The car runs very well.I forget the Bosch number but the flow rates are easy to look up by the 9 digit part # on the injector.
To Bosch EV14
